400HP,
As usual with most coil-overs they come in variety of different types from stiff to very stiff, and some with bound and rebound adjustment. They use these on V8 supercars and other high performance racers. They are extremely well made, but just buy them for a purpose, not just to lower the car.
I have full racing coil-overs in mine, which are very stiff on the road, but excellent at high speed cornering.
See'ya :burnout:
https://www.sau.com.au/forums/topic/7581-ohlins-coilovers/#findComment-111031
I have a set on my 'line. I personally think they are awesome. Not harsh kidneybelt material. I haven't tried them on the track - a few more mods before I head down that street, so to speak. Roadholding is excellent, height adjustable via a circlip type setup, adjust in about 5mm increments (I haven't acutally measured them). There is a damper adjustment on the rears -mine is set to four for general street driving and that seems to work fine. I do believe that they are a bit rare on street cars 'cause new they are around 1g a corner, though I got mine alot cheaper second hand. To sum up, I am very, very happy
Steve
https://www.sau.com.au/forums/topic/7581-ohlins-coilovers/#findComment-111139
I'm sorry, I dont know what model they are. I got mine for $1300 in what can only be described as excellent condition - bought them through a tuning shop but that price was alot cheaper than normal 'cos I have been dealing with them for a while. Another thing with Ohlins is that they can be rebuilt in Aust, so it might be worth checking out how much for a full rebuild, as you can pick up Ohlins for alot less than what I paid. I have seen examples for as little as $900 in the for sale section on this site.
Edit: try www.ohlins.com
https://www.sau.com.au/forums/topic/7581-ohlins-coilovers/#findComment-111582
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
