im rebuilding my RB20 after cracking a piston, again. im putting CP forged pistons in and was just wondering if there is much to be gained in porting the head, as in $$$$ Vs hp gained.
Has anyone had there 20 head ported, what hp did it end up flowing compared to standard.
who on the Gold Coast or Brisbane would you recomend to do this work.
https://www.sau.com.au/forums/topic/75860-porting-a-rb20-head/
the problem with the rb20 head which is the same casting as the rb26(rb26 everything is just way bigger ie. ports, valves, cyclinder chamber, is everything is so small and alot of it you have to keep like that!! Around the studs on the exhaust for instance is a big chuck of alloy to strengthen to the stud which on an rb26 you can remove as the studs are further apart as the ports are bigger on a rb20 you have to keep them. Id suggest for the money you will spend on die grinder bits and dremel flat polisher sand paperbits, around $200+, I would by a garaunteed performance enhancer such as adjustable cam gears or something along those lines....
Cheers.
was going to get it profesionally ported, im chasing as much hp as possible out of the 20, and before someone says it i dont want a 25 or 26. im sticking with the 20.
the engine is for drift. chasing around 400rwhp, i have seen a rb20 do the numbers on a dyno so i know it can be done.
Dude, get out your whitepages, and call JH Hill. He does the BEST work. Ring him, make sure you talk to John, and see what he thinks. Many of the faster cars in brisbane have been there weither they know it or not.
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
