  • Replies 105
Posted Images
moanie, i got done by an arsehole of a cop, in singleton, by the name of Smith, he has a bad name around the hunter valley, nobody likes him, has been alot off petitions to get him off the force as he is just cruel.
he let me off with the box in place. ive never heard of it having to be in a plastic box, alot of cars have metal airboxs. they went to plastic for the cost + weight.
thanks for the compliments guys, sorry Mark, but she looks similar to alot of other 33s around, so shes going to get changed from classy to drift spec... i love it how it is but i want to stand out.
doodz, the airbox is piss easy to install. im sorry but the allen head bolts are staying, they look neater, im not putting thumb screws on there, just carry the correct allen key in your car. hell, ill give you one if you want me to.
cheers
Linton
hmmm... you sure?  maybe it was the luck of the draw?  as in a semi nice cop?  i've just been done for my pod twice, and both times i was told it HAD to be a plastic box :D  just don't want to risk it a 3rd time, unless i'm sure i won't get done!
You can never be 100% sure because the written law can be interpretted in whatever way the indiviual likes. To a certain extent of course.
But in all honesty, from everything I've read and heard, living in Sydney you're going to be way more likely to get pulled over, and the police there seem to defect you guys for everything.
In other areas, you will usually not get pulled over unless you flaunt the laws time and again.
I'll see what documents I can find online though and see if we can get a proper reading of the rules.
Will that put your mind at ease Moanie? :crazy:
that'd be great monkeyk!! :O
NZM - I love the box!! it looks sooo neat!! i *tried* to make one myself, but i was going to use fibreglass and i didn't know how to cut it!!! i ended up putting the stock plastic box back on... when i went back to the epa to clear my defects i asked the guy about it.. he said that nothing but plastic would do :P it sux :) i want i sexy box like that for my filter!!! :( and yeah.. guess i'm just scared of getting done a third time.. it won't be pleasant! and it'll be too $$ for me to fix :( but dammit! i want that box! lol!
Nice job on the box mate!
hehe, they look similar to the one I run at the moment, but your offering them at a good price.
I currently run a similar set up to linton, and I also run thermal insulation in the lining of the box, to prevent heat soak...
I also run CAI running from the corner of my 400r front bar, and only get a tiny bit warm... not even noticeable to be honest ;)
yeh, im looking at different types of insulation, but these will be a "Deluxe" box that will cost extra.
ill do a temp. test when i can find a thermoprobe long enough to reach to the airbox, mine reaches to the turbo at the moment.
i thought it would be slightly easier too moanie, but anyway, now that ive got the first one made, i can go see where it could be improved more and go from there.
cheers
Linton
lwells, dont get quite what you mean.. you mean a full bolt in replacment airbox?? as in the ARC type. then no.
it is an enclosed box/shield for your pod filter, so you dont get defected for it. and also a bit of bling in the engine bay.
cheers
Linton
I don't quite know how else to phrase it: is the pod fully enclosed in the box (with an entry for the air duct and the pod/afm), that is, does it have four sides, a top and a bottom, or is it just a shield that sits over the top and down a couple of sides?
Lucien.
yeh, there is one for the stock piping....just has an extra hole and requires a little more work to install.
hopefully have them done when the bender turns up... i have been cutting them out though, ready for bending, if it doesnt come soon, ill make some up using the old way, it still works fine, just takes a little more time.
cheers
Linton
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
