R32 GTSt manual conversion
B0oStEr
 Share
Even when I find a box it's all the little things you need that make this difficult.
Not having been through this with a Skyline before I can only guess what is required.
My list so far if anyone cares to comment.
Gearbox/ bellhousing bolts/ g/b crossmember/ mount/ brackets?/ coverplate?/ clutchfork/ release bearing/ nuts and bolts etc.
Flywheel/ flywheel bolts/ spigot bearing/ pressureplate and bolts/ clutchplate/ slave cyl. and bolts/hyd. lines/ master cyl./ pedalbox with nuts and bolts.
Gearstick boot and surround/ gearknob/ instrument cluster surround.
Speedo cable/ loom for reverse light switch, inhibitor switch bypass, gearstick position sensors.
Manual ECU
Tailshaft
Starter motor?
Anything else I've overlooked or maybe something I've listed is unnecessary.
Anyway let me know if you have any of these bits for sale.
Thankyou.
i have the parts i have listed here in toowoomba about 1 hr from brissy like i say $200 cash for everything i have here....
Considering the need for every nut and bolt I think my best bet is a half cut.
I'm keeping your parts in mind in case someone offers me a package minus the bits you have.
I don't want to rush out and buy all the main bits and then find I still need dozens of small bits of little value that noone could be bothered looking for.
some one posted that they got quoted 2k to do a full manual conversion on a r33, if you know much about r33 the boxes arent cheap, so thats really really good price, i wouold sugest going and finding that thread (it was only a few days ago) and i tihnk it was in brissy to. For 2k fully converted, using the stronger rb25 box, id go for it
  • 1 month later...
I have an R33 GTS25t 5 speed complete. Came out of a car with just 80000k on it it and it's yours for $1100.00. I can also supply an RB20DET box from a R32 GTSt for $400.00.
I have a billet STEEL flywheel and VL Turbo clutch plate all brand new.
Contact me by PM or [email protected]
IF your still interested.
Cheers,
Dennis
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
