Idling Problem with and R33 GTS-t
Guest Ismail82
Just wondering if anybody can help me or if anyone has encountered a similar Problem with their R33 Gtst Skyline.
After I drive the car constantly, meaning visiting various places and switching the car on and off, it becomes very rough and it lags. What i mean is that the idiling is really rough and will jump from 1000 to 3000 back and fourth, until i turn off the car and let it stand for about 15 minutes. I have cleaned the injectors. Also when this happens and i continue to drive it without letting it stand switched off, it is really lagging. I press down on the accelarator but it does not go how it should. I have spelt petrol fuems while i am in the cabin but whenever i ask whoever is with me if they smell it they say they cant. Has anyone else incurred a similar problem or know of anyone who has it would be really appreciaited if you could contact me and help me out. I really like driving the car but currently am afraid to in case it cuts out anywhere when i am out as it does.
https://www.sau.com.au/forums/topic/7589-idling-problem-with-and-r33-gts-t/
Could be your AFM (air flow meter). Either way, smelling petrol inside the cabin is never a good thing..that could indicate a leak somewhere or your engine running extremely rich. If I were you I would take it straight to a mechanic who knows what they are doing. Could save you money in the end.
Sounds very likely it could be that...although then again it could be anything. Apparently that happened in my car with the previous owner (ethanr33), so he used it for a good reason to whack an Apexi S-AFC in - of course with the additional power benefits.
Common problem?
Guest BlitzoGT
Hey everyone,
At last I see people with the same issue as I :P
Ismail82 I know how you feel, but mine doesn't hover as much as yours (i.e. around the 2-3k rpm mark).
Doesn't anyone know of a good and reasonable priced place that can do the dyno tune or the Apexi S-AFC as I too am getthing the same problem as Ismail82...
I'm located inner city area but willing to go anywhere that does a good job...
Guest Ismail82
I cleaned the 02 sensor with oven cleaner, as recommended by my mechanic. As of today i realised that cleaning it works only for three weeks as the same problem reoccured today. Time to change the 02 sensor and probably the Air Flow Ceonsor with a S-AFC as recommended by others.
  • 3 weeks later...
Guest Ismail82
Hey all,
I left the car with the auto electrician for a full day. He hooked it up to the computer and ran tests to find that their are no faults with the car. O2 sensor is fine Air Flow Meter is Fine. He reset the computer and ran the tests again and again everything was fine.
He was confused and so am I. How come it would idle rough like that and become sluggish and yet everything registers as being fine. Does anybody at all have any ideas of how to rectify this problem through their experience or do they know anyone I could contact to get this sorted out.
At the moment i am driving but every now and agian it happens and it is so annoying. thanks to all
I'd still suggest getting it on a dyno, they can monitor what is happening to the car much better that way. It is most likely a fuel related problem, so they will be able to tell if it is too rich or not firing etc.
It's well worth the money.
See'ya:burnout:
Definitely get it on a dyno for a diagnosic run as has already been suggested. Get them to check your air-fuel mix, fuel pressure and whatever sensors they can.
I went from 95hp and really lean, found my coolant temp sensor was dead, went back to 150hp (with a badly slipping clutch) and all is well again.
Apart from the clutch.
Your problem may not be and probably isn't the coolant temp sensor, but it's an example of how a good dyno diagnostic run can pick up these things.
Sounds like the same problem that I had? I cleaned out the auxiliary air control (AAC) valve, and it worked!(reading these forums can be helpful after all)
Its located at the back of the plenum chamber (inlet manifold) there is a maroon electrical plug (brittle) and a hose which need to be removed first then there is four ten millimeter bolts that also need to be removed before the whole assembly can be (careful if you want to use the orignal gasket again) removed from the car.
then there is two screws that hold the solenoid on, once this is removed the remaining assembly can be cleaned by useing carby cleaner (I used kero and a compressor to dry and clear any blockages) also make sure that the spring moves(smooth) and the valve works.
Reassemble in reverse order with a bit of sensor safe silicon with the original gasket(or you could make another one it depends on weather the gasket comes off in one piece) hope this helps!
It really is quite easy!
The stuttering might be spark plugs, have them gaped to 0.8mm this helps (platinum/iridium plugs also are a good choice for turbocharged engines)
MEGA
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
