WTF?
Are you guys serious? Was it a bloody terridactal egg or somthing?
u obviously dont know what the contents of an egg does to paint ;) not to mention the shell on impact.
IF YOUR CAR EVER GETS EGGED WASH IT OFF THOROUGHLY AS SOON AS U SEE IT.
Never let it sit there... even if u rinse it.
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1395415
yeah, unfortunetly this happned at night and i didnt see it till the next day evening. i washed it off ASAP, just on the spray. used a soaked mic-fiber to do the rest, but still theres lil scratch marks.
only if could get my hands on the bugger who did it!
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1396123
In what areas have these egg attacks occured?
I can't believe how demented people are in this day and age to have no respect for other peoples property. We drive a Japanese car.....WHATS THE BIG F*(kiNg DEAL?! Its just plain sad for people to have such a hatred for what....a car?
Anyway, I can just imagine the damage on a black Skyline....makes me cringe.
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1404223
hmmmm I say we go vigilante on the pricks.......teach them some discipline.....so that the next time they see an egg, they'll fall to the floor and start shivering like a mouse on crack that's been poked with an iron rod........repeatedly ;)
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1404231
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
