Ban Turbo Cars From P Platers? Just wanna know where this stands...
  • Replies 106
I found, r32 Gts-4, r32 gtr, Evo VII's (an odd one), Evo club spec 2 and 3 wrx's, early celica gt-4s, 98 supras, and just on a trivial note, stacks of volvos have been banned, yet they are (supposedly) some of the safest cars around.
Just a quickie for you current p platers out there:
I called the RTA this morning, and basically "if you are caught doing an offence, that disquilifies your liscence after or on July 11th, the rule will affect you" If you are currently serving an offence, but get your liscence back on July 12th, it wont affect you.
If your loosing all your points, this counts as a "SUSPENSION" not a DISQUILIFICATION" which means you can still drive your vehicle, after the suspension period is over...
Hope this helps you current p platers...
No because it doesnt affect current P Plate holders, an if you are gettin your Green P's then you already have your red P's. So therefore it wont affect you.
If someone rings the RTA in the next couple of days, would you mind asking them about if a car isnt on that list you can drive it? Much appreciated.
Cheers
OC
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
