I've had this weird smell from my 34 more or less since I got it a month or so ago - i've noticed it a bit more lately. It has had new exhaust (3" system), clutch (heavy duty single plate) and brakes (new standard nissan pads) but the smell doesn't seem like any of those.
It does it after a bit of driving - not necesarily giving it stick, and you notice it mostly when stopped at lights. The best way to describe the smell is like 'gunpowder', or if you've ever seen those balls you can get that crackle when you hit them togethor the smell is just like that. The car has been at several mechanics with various work carried out since i've noticed the smell and they haven't found it either. Its not that bad but it certainly shouldn't be there. I was wondering if anyone may have experienced anything like this.
Its definitely not the smell of brakes or clutch btw - bear in mind i value cars for a living and have never experienced this smell before..
Any help would be really appreciated,
Paul.
https://www.sau.com.au/forums/topic/75957-strange-smell-from-r34-gtt/
Yep that's the new exhaust smell, we had a daewoo that used to make that smell when you gave it a bit, the smell eventually starts to dissapear.
BTW drive past your place a fair bit, got some nice 34's there, especially the red one!!!
Its definitely not the 'new exhaust smell' - I know exactly what you mean, that only lasted maybe 50kms from when I got the zorst done. I didn't think anyone would know, just thought there may have been a chance.; its a really unusual smell...maybe its me :whatsthat
If it does sound familiar to anyone let me know your thoughts. If I find out what it is i'll let you know.
Btw im pretty sure its not the cat as well.
I might take it to the exhaust shop to get them to check for leaks in the system, although usually you'd hear that..
Dan - yer we've got plenty, not selling as many as we anticipated, I think all the 34 buyers are on holiday....
  • 3 weeks later...
I changed the dump pipe and CAT on my 33 a few weeks back and noticed this same smell. Initially I thoughti t might be an exhaust leak, but after investigation it appears to be just 'new exhaust smell' as well. It has gotten less noticable as it wears in but I still get a whiff after giving it some boot. It's probably stuck around longer as the dump pipe is thermal wraped and painted with heat proof paint.
  • 5 months later...
Motorman, I have the exact same problem as you.
Cant reproduce it and it happens only every now and then.
I noticed that after I changed my engine and gearbox oil the smell did go away.
I cant remember the last time I experienced that smell. But every once in a blue moon it does come up.
Did you manage to pinpoint what the problem is?
The japs could have installed a gearbox "breather" or similar.
What mine was... a small tube from the gearbox, dunno where it was connected too, that ended in the engine bay like a breather.
The smell would then come back into the cabin. weird smell that was.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
