hey all,
i am thinking of selling my car and have not been in the skyline game for long and i dont have much idea what it would be worth.
so basically i just need some help with a ruff value of my car,
so here we go:
CAR:
1989 impul spec r32-r skyline (4 door) also number 187 out of 250 made.
rb20det
auto
100,xxx km
MODS:
hks intercooler
hks mushroom pod filter
custom oil catch can
custom boost upgrade set at 0.8bar
impul 3" catback zorst
impul front strut brace
impul computer
kyb adjustable coilovers
slotted and crossed drilled rotors
original p1 buddyclub wheels (front 16x7.5", rear 16x8.5")
good condition falken tyres
full impul spec bodykit
fibre glass bonnet
momo steering wheel
omori guages (boost, oil temp and oil pressure)
greddy turbo timer
vdo mp3 headunit
alpine type s front speakers
tinted windows
(pretty sure that is all mods listed)
recently resprayed silver with black with blue pearl bonnet
front bar has been re-fibre glassed and renforced b4 respray.
so basically just need a ruff idea on what it would be worth,
any help would be good,
thanks
matt.
hey mate
Ruffels here, the kid round the corner with the white 33
like i said, i recon u could ask 18k for it, perhalps more
would be interesting to see what people have to say about this
is an awsome example of a 4 door 32 !
-Ruffels
yeah baz... keeping in mind its a limited edition Impul... in imaculate condition
how many of the 250 made would be in australia, and in this condition
i think its worth more in my opinion
-Ruffels
Looks awesome man, but I think the auto thing might be an issue, as its probably more of the "DRIVE ME" style. So anyone who wanted it would probably see auto as a downside, like maybe even start thinking in their head, "+ manual conversion", that makes it more than what you are getting and pretty pricey.
Maybe you can find someone who is too unco to drive manual...
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
