Ok, Im looking at sway bars for the cefiro, as Im still not happy with the set up even with rasing the car, the corner balance, numerous oppinions and suggestions (which are all almost identical) in terms of front end set up with camber, caster etc.
Sooo, pros and cons of them. How do they work, why are they needed/not needed. Is adjustable worth the extra money, and finally, Id be using S13 ones, the cef is obviously a fair bit more heavy, and this Im guessing would be even more so on corners, braking etc due to inertia, so keeping that in mind would I need to go bigger.
BTW, the idea of the car is good for normal street driving, more spirited street driving, and then for some semis to be thrown on the car for track stuff. Basically set up for fun, not professional race car or drift car.
Thanks!
https://www.sau.com.au/forums/topic/76017-sway-bars-yes-again-i-searched/
  • Replies 43
swaybars will not affect the ride or comfort in a straight line, they dont have the same affect as shocks and springs or bushes... their proper name is anti-roll bars.
they connect the chassis to the control arms and hold it stiff through out corners, reducing body roll, keeping the car centred throughout the corner. alot of coilovers are that stiff that emphasis on swaybars is not so important. if you want to see how much of an affect swaybars have, remove them all together and go for a drive...body roll central as the car is relying on the springs to take the weight of the car + inertia of the corner.
they dont affect castor or camber, or any alignment specs.
aftermarket adj. s13 ones will be fine in the ceffy, they arent that much heavier. yes it is worth getting adjustable ones.
hope that helps
cheers
Linton
Probably the thing to recognise is that the anti-roll bars don't much affect a car's ride/handling compromise in a straight line. It's the dynamics of lateral weight transfer when changing direction (turning) that they impact on quite significantly. Adjustable bars can give you the option of quickly altering the dynamics, say if you wanted to induce specific characteristics for drift or circuit work.
For handling upgrades there seems to be two schools of thought: big bars; and high-rate springs. Anti-roll bars at least allow you to retain ride quality and power-down because the wheels can maintain closer contact with the ground imperfections rather than the chatter that can occur with rock hard springs. Adjustable bars allow you to mimic the effect of installing different size (diameter) bars by changing the leverage rate between the bar and chassis. Using them just gives you the option of making the car respond differently, quickly.
Anti-roll bars are actually a laterally mounted torsion bar (spring). Because they store and then release engergy, they impact on the RATE of lateral weight transfer and hence the rate of suspension movement, they control the rate of camber change that a given wheel experiences in that cornering moment. So yes, bars will not affect your static suspension settings - but in the dynamic environment they will. That is partly how changing their sizes brings about handling differences.
I looked on the whiteline site before, and they seem to be about $500 for a set (havent done the normal run around to find the cheapest price yet).
I was going to say is $500 worth it compaired to say 'X' something else, but I dont think there is anything else that I can do without going nuts.
Im still interested to know someone whos done some track work with out them, but say decent suspension gear, then got the sway bars on, and whats their lap time improvement been like.
Same springs, same shocks, same tyres, same camber , same caster, same engine power, 3 seconds a lap faster at Eastern Creek.:cheers:
Aftermarket sway bars are a 'good thing', but to say they dont affect ride comfort is simply not true. A heavier sway bar reduces the 'independance' of the rear suspension, and thus ride quality is definately affected.
I got a whiteline swaybar for my r33, it was like just under $200.
I've got no clue about racing/suspension etc etc, but I think it made a differance to the handling, the car was more reponsive when turning, Kinda made it feel abit heavier and smoother. It felt safer and more comfortable going round the corners faster than before basicaly.
Not a big issue that, with the suspension and the diff, its not that comfy to start with :)
ionos.... ive had heavier swaybars fitted to all my cars, havent got any for the 33 yet though. but on my honda, r31 skyline, and my 00' subaru liberty, and didnt notice any change in driving in a straight line, also made cornering much more stable and comfortable, body was all over the shop and carrying on.
what makes you say that ride quality is affected??? with swaybars, there is no downside.
They are going to be put on the back burner for a bit anyway. Spoke to another suspension shop and they seem to think most of my problem is set up (and they said new whiteline price list is coming out soon and they are going to be cheaper). But he seems to think TOO MUCH castor, and too much rear camber. So what he is saying is fix that up first, see if thats whats causeing oversteer still (which he was quite sure would be). Then go sway bars after that to see what effect they have. But he didnt want to try and bandaid the problem.
Daveo - not to hi jack but I'd like to post some observations from a drive I recently did and the things I noticed and if they're the same as you are trying to get rid of.
Basically, 2 things. One was I seemed to get a lot of 'washy' understeer from corners around 70-100kmh which resembled driving a GTiR. That is, it wasn't full understeer but enough for me not to like and feel the front wheels slipping through the corner. This was not at redline but probably about 50% rpm or less (because I didn't feel like coming off the corner heh heh so wasn't pushing it).
The second was when braking late (I didn't anticipate the corner being so long and so angled) the car really REALLY felt like going to the apex. Fair enough I realise that's just bad driving but it was the first time I really felt the weight of the ceffy. I would have thought you can counter this somewhat by suspension settings.
Are these the things you are also experiencing? Because as far as I know I don't have sway bars (or if I do they're stock).
Not hijacking at all dude, its good to see what others cars are doing.
The first bit kinda... atm I find my car really quite settled, never too scared to keep the boot in. Plus we have changed mine so it WONT kick out, it just seems if I power down, it goes straight (no where near as much as it did before we raised it 2inches) And the outsides of my tyres are still wearing more than the outside.
I find with braking tho mine is fine, I'll out brake most cars, doesnt feel heavy or anything. And I still need to get braided lines, and a brake booster stopper on. But I did get the sensation you are taking about, its more so a mental thing I think, as you reaise its getting a bit close a bit fast, so you think the car isnt slowing down. ;)
......he seems to think TOO MUCH castor......
That seems an unusual thing to say. The only real downside to heaps of castor is heavy steering, and since we all run power steering thats not an issue. How much caster are you running?
Daveo - cheers.
1- When you say straight - do you mean straight into the apex against the way the wheels are pointed? if so that's what I felt.
2- My brakes are great, r32 type M + project mu brake pads. The feeling I meant was the car had no problem stopping, but if you picture heading round the corner, just before the apex, lock it up and you'll head straight out of the apex and off the track. This is the sensation I mean.. the feeling that the car is just... very much heading out of the apex on a late brake. I know you'd get this with any car but the ceff I just felt it a helluva lot more (for what seemed to be not much late braking at all) than I expected.
What he is saying is it induces bump steer etc, and for the extra bit of stablity you get its not worth it. Remember cefiro is S13 suspension, so not as good as skylines.
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
