Hi guys i am currently looking at putting a pod in my car for better airflow but i really dont want to be defected for it. Does anyone know if putting a pod in makes much of a diffrence or is it just better to put a better filter in the standard airbox? Another option i thort of is putting a pod in side the air box to hide it and cutting away a bit of the airbox for ventalation, but i dont know weather it will be worth the trouble.
Any information will help
thank you.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/
use the search function on the site, there's heaps of info on this topic.
I have replaced my blitz pod with a k&n panel filter in the stock air box, and havent notices any difference in performance. I've done this as i'm upgrading my stock intercooler and want to keep everything legal.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1394377
thank you.
high-flow panel filter in standard airbox is your friend...
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1394391
Pannel filter in airbox is good but when I put my cooler on I could not put the CAI part of the airbox back on because the piping was in the way so it was sucking hot air. I put a Apexi pod on, partitioned it off, and ran a cold air feed from the front bar to the older cooler piping hole under the pod. Made a difference in my case.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1394900
Just curious, I was at the autosaloon and they were selling ARC box filters.
Would this be legal in NSW? or would it be treated just like a pod filter?
Obviously any police seeing an ARC box would know it's not standard.
also are they any better than pods?
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1395407
this is how my car is, no snorkel due to fmic piping, so i too have bought a pod and when i fit it will box it as you did.
so it did make a noticeable difference? small or big? i will be using an apexi pod as well so im interested since its the same situation.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1395413
I have only had it on for a couple of weeks difference in performance is small but there is a lot more induction noise witch I like. I have noticed a difference in fuel ecconomy. ;)
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1395481
  • 3 months later...
since i posted last i fitted an apexi pod with cold air partition, and report back that it made very little difference when compared to a stock airbox without a snorkel.
actually, if no one told me that it had changed, i doubt i would have felt a diff at all so NO difference.
main difference is in the sound, it is extremely annoying on the freeway and i want to get rid of it on long trips :P
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1575746
You can have any kind of filter you want, providing it is in a box of some sought. There was a mssive thread on here about CAI and airboxes, i think the results showed the pannel filters flow better, i may be wrong, but im pretty sure that was the case.
Good luck!
In Vic you cant have an oiled filter. But a pod doesnt have to be in a box. But you cant have a pod and an intercooler.
It would help if you say which state you are in before you ask questions about legality of mods, as all states have their own rules.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1575777
ive just installed an arc box in mine replacing the old box and performance wise picked up some mid range. but after a while you can feel the car suckin in hot air. only way around it for me is to chop and modify the original snorkel for some cold air induction.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1575796
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
