Hey all,
Just wanted 2 share my good news with u.
My car is featured in the latest HPI mag (should be on sale by the end of the week) as a 5 page article! (Pages 78 - 82)
I am so stoked about this as this is my fav mag ever & i have been buying it 4 years now & it's like a dream come true 2 have my own car in there.
Even more exciting is i can't think of the last time if ever they featured a girls car in a story so even more of an achievement.
Only let down is the photo shoot was done months ago now before my new interior & custom fusion boot install was put in.
Anyways hopefully u can all check it out & let me now what u think?
https://www.sau.com.au/forums/topic/76045-high-performance-imports-no-55/
Cudos !! It's a great feeling ( I know ) but a word of advice from someone who's been there, now that everyone ( that includes the *##holes ) knows your car and what's in it, it becomes even more of a target for theft so be extra carefull.
Hey all,
whats so special about ur car?
  • 2 months later...
i do appologise i only saw this now...
i'm not really sure what u mean by this? are u wanting me 2 tell u what i like about my car or do u think it is 'not worthy' 2 be in there?
well i guess u can't please everyone but these pics were also without my new interior & stereo/boot install (see sig below) - next week when i will have my car back with new engine & gearbox i wil be sure 2 post some new pics up - even the harshest critic will be sure 2 give respect when it's due - will be a full blown race car that can still be driven on the street - not too bad 4 a car that has a stack of performance & looks okay too - oh yeah & is owned & driven only by a female - that's what i like about it anyways....
btw please feel free 2 post pics up of ur car, i alway find that ppl who make comments like these either 1. do not own a car or 2. have a car that doesn't even compare 2 the cars they seem 2 so easily bag out...
Edited by oor33sky_
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
