Hey guys,
i was thinking the other day (quite painful it is... don't plan to do it again any time soon :))
What about a Jap style swap meet? We could go to a carpark somewhere (would need to be big and open and have free parking and not interrup people's social lives)
and we could sell / swap parts amongst each other...
I'd be willing to do some organising and arrange for food vans etc to be there as well. i think it would be an interesting day, bring your cars, parts and accessories you have for sale and try and sell them. (if it where successfull we could hold them regularly as well :))
gimme your opinions guys.
Cheers,
Dave.
https://www.sau.com.au/forums/topic/76090-how-about/
yes, I like the idea. maybe some big vendors can come also and show their wares?
A Japanese-import flea-market. Will have to arange for a public space with a council somewhere first, or else just meet up in the dead of night Wangan-style :)
https://www.sau.com.au/forums/topic/76090-how-about/#findComment-1395629
  Binky1970 said:
If your looking for a place to hold this little shindig then I recommend a drive in movie theatre.
That's actually an excellent suggestion :rant:
They have a massive amount of space and easy entry and exit... I wonder if they'd let us use the carpark for free though :confused:
https://www.sau.com.au/forums/topic/76090-how-about/#findComment-1396466
Great idea!!
BTW my sister just attended the Pomona swap meet in Los Angeles on sunday just gone, queud up for a mile, got in at 6am and didnt see everything for sale by the time they left at 3pm. Biggest swap meet in the world! And no she didn't buy me anything for the gtr..
https://www.sau.com.au/forums/topic/76090-how-about/#findComment-1397648
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
