Wolf3d V4 help
I am helping a friend of mine tweak his wolf3d in a r33 GTS 25T. We got it dyno tuned when it was installed. Unfortunantly it is running so rich that unburnt fuel is comming out at idle and you need to use the flood control to start it.
I am just wondering what injector times people are using for starting and idling an rb25det? Currently it is 6ms for the start and 1.54ms for idle.
Any help would be great.
Thanks
i have been told by some performance mobs around the place , about the wolf 3d v4
cause i was after a ecu for my r33 auto
mercury motorsport apperntly can do the tune and whateva , but they are located in brisbane.
but have heard the wolf 3d's are more suited to a commodore or somethin like that rather then a turboed vehicle.
As mercury motorsport, (from memory) have dealt with these ecus b4, i would talk to them about it. mite be able to help over the phone, but ya mite have to take it into somewhere.
l8ers
Mine was running fine but unfortunately I wasn't involved in the tune process, i'd recommend talking to SST Steve but I don't think he comes on much anymore. Another option would be to contact Matty Spry at PITS on GC as he may be able to help you/
I'm just having a look at the standard map steve sent me, my starting fuel rate is 6.00ms and the idle is that the figure in the bottom left corner of the fuel map? if so then that is 1.29.
hope it helps and I hope i'm right.
PM me your email ad and i'll email you the map so you can compare:uh-huh:
just got mine installed by Mercury Motorsports today.. unfortunately due to lack of time they weren't able to tune it properly.. they asked me to leave the car another nite as they need to have a cold start tune up but i had to head back to the coast and needed the car for work.
still idleing bad from time to time.. im expecting a bad cold start in the morning..but will take the car back next week and hopefully the problem will be solve by then.
they are having a hard time to by-pass the turbo timer though,.,has anyone had this problem ? as my turbo timer isn't working.
yeah we had problems with the turbo timer. Whenever we tried to start the car it would come up with a message saying that the turbo timer mode had started and we whad to wait. It ended up being that the battery was dropping down to 5v. The wolf works all the way down to 6.5v. So get out the trusty multimeter and check the voltages on the battery termainals as you try to start the car.
If you are trying just to disable the torubo timer it can easily be done through the laptop software or the hand controller. The instructions for the hand controller should have come with the ecu. But you can grab a pdf copy from http://www.wolfems.com.au just don't ask me for the exact page because their website sucks big time.
Would anyone recommend these over the PFC...???
I want to get rid of the AFM, and have heard mixed responses about the wolf which uses a MAF...
Also the idle problem is common, as someone mentioned Mercury or Matty at PITS will be able to help
only problem with wolf...its huge and doesn't fit where the ecu were so it needs to be mounted elsewhere.
and its a bitch to tune but this is bec. PFC is too common and almost everyone can tune them nowadays unlike the Wolf..not many good tuners around.
i think PFC is more compatible with the turbo vehicles, also being like you said, there are pretty much most skyline that has modded their car, and is MANUAL, to a reasonable HP, have used this type of ECU
Cause ppl know it works, and know ppl that can tune these ecu's,
for the price too PFC 980 to 1500, ranges abit,
but as from ppls experiences , and seein ppl usin them, seems to be worth the money
as i havent had the chance of havin one...... yeettt!!!!
i dont know, so and only goin what i have seen, read, and heard. BUT its good enough for me.
I'm goin to go with the PFC, and recently just changed my car to manual, cause of ECU optins was very very limited, To the fact that i couldnt find one that works.
And was resorted to a piggy back, or tweaked standard ecu.
Also depends what hp ya chasin aswell i guess.
Anyway hope everything goes sweettt assss!!
well works well, as i havent heard any complaints about PFC's on skylines
or anything going wrong.
As for wolf 3d's with this thread looks like theres a running rich problem,
and looks like its quite common, with all skylines.
Maybe its just tuning problems with wolf 3d's, ppl dont have enough experience with them.
Or maybe there just not suited for skylines, which i have heard that wold 3d's are more suited to a non turbo vehicle.
As im sayin PFc more compatible, i' probably should of said seems to work well,
ppl know how to tune them, theres alot of them around, and for the price is good.
As i havent had one , just goin by hearin, seein, and readin , thats all im goin off .
Wolf3Dv4 user here and couldn't be happier.
My car does have a little trouble on cold start up but that's because it was initially running too rich and flooding itself while trying to start. I also was a victim of the "please leave it for one more night, we need to tune the idle/startup"... I couldn't wait and took the car anyway and then had the starting issues.
Lowering the fuel allowed it to start every time, although the idle on startup is now a little weak. Once it's been going for 20 seconds, it's perfect.
As for how they run on turbo engines?
460hp Turbo
3inch Exhaust
FMIC
Atmo BOV (showing this for a reason even though yes it's a lame mod)
Fuel Pump
STOCK Injectors
243rwkw @ 16psi.
Have been driving it for 6 weeks now. Has NEVER backfired or missed a beat. Pulls all the way to 8000rpm (when I'm not paying attention to the revs :cheers:) without misfiring or coughing or spluttering. MAP's rule. I can pssscchhtttt all day long without that aweful backfire it used to make.
Everyone who has checked out my car has commented on how well it has been tuned.
Work done by WASP on the Gold Coast with tuning done at PITS.
Could NOT be happier :0
Why?
Can't be fuel economy, an AFM is demonstably superior as it measure the actual air flow into the engine.
Can't be emmisions, an AFM is demonstably superior as it measure the actual air flow into the engine.
Can't be power, I have seen a GTR with over 1100 bhp running AFM's
Can't be 1/4 times, I have seen a GTR run low 8's using AFM's
Can't be terminal speed, I have seen a GTR with a TS over 160 mph running AFM's
Ok I give up, why do you want to get rid of the best method of measuring load on an engine and substitute it for a MAP sensor that guesses load by measuring pressure and then calculation and extrapolation?:cheers:
if it was a NA car i would agree with getting rid of the afm to allow a phat intake. But the force induction system doesn't have a big a problem. The whole reason to big intakes in NA is to allow higher pressure air to reach the engine. This really isn't a problem when running boost. If you can tune to the afm you will be able to get much more precise maps running.
Point taken, I have never run AFM's before...always a MAP, this is of course with iron big blocks with blowers and turbos
I just don't like the fact that something else has to be plumbed in along the line. I was merely asking for peoples opinions.
The other fact is that the AFM is not COMPLETELY accurate otherwise with excellent tuning the PFC should eliminate backfiring.
Its good to hear all these cars running low numbers with AFM's...however that is all good and well but that proves nothing. They would run the same power and numbers with a properly tuned MAP sensor ECU...
And last time I checked, I never wanted to run a 9...or a 10...or even an 11.
Alot of the time ECU choice is a decision made taking into consideration many factors, and pulling ya pud with figures about other cars has SFA to do with the question at hand.
Also tuning the af maps more precisely with an AFM isntead of a MAP is like comparing apples with oranges. That is a load of you know what in its self. Find a good tuner and the results will speak for themselves.
Good luck to the bloke who has the start up idle problem, I am sure Matty at PITS will be able to help. Was talking to a good performance friend who was with him the other day and he said that its a relatively easy fix.
This is tedy here. It seesm like the problem is that the idiots that tuned the wolf never setup the closed loop system. So it is running a quick tune all the time. Also the o2 sensor is shot. So the weekend we will be setting up the closed loop and running a working o2 sensor.
 Share
    • Hey guys any recommendations for fitment for a stock 94 GTR R32  Want to order work meister s1 3p and would like a nice looking flush fitment. Plan to get MCA coilovers to set ride height etc. Just confused on offset, brake clearance etc.  Never purchased after market wheels so I'm a bit concerned since it's a long wait to order and I don't want to order the wrong specs.
    • Update: Done: -Running on 6 cylinders, one injector was gummed up. I made an injector tapper, bit of Teflon on the end of a metal rod.  That fixed the injector. Need to replace one injector plug, the fastener is broken. -Coolant bleed -Fixed 4WD warning light, bleed 4wd system -Fixed electrical problems: alarm, brake lights, various broken plugs  -Got all the parts ready to connect head drain. Head drain is fitted with a blocker atm Todo: -Fuel pump dead, Been cleaning out the tank, had a lot of tobacco looking stuff, think its OEM foam. Got a Walbro 460 to put in. Probably going to add a relay to give the pump a solid 13volts. Replacing all the fuel hoses, in tank etc. -Front drive shafts still not back on. Waiting on parts. Would like to buy some new ones, but probably going to patch these up for now -Replacing gas struts on back door. Waiting to be returned -Headlights need a polish/repair -Going to touch up the paint a little. -Clean up the interior -Connect up heater plumbing -Cosmetic stuff, powder coat replace rusty parts, replace rusty bolts, wiper blades, silicon missing rubber -A million other things
    • Don't do this unless it never gets hot where you are.
    • Upgrade time. Been a long time coming, but I was able to get my GTR to a reputable builder in the States. List of upgrade parts below: RB30 (Sourced from Australia) PRP RB30 timing belt kit with all options Nitto pistons Nitto I beam rods Nitto oil pump King engine bearings New RB26 Head (Grabbed during Heritage run) Kelford 272 cams mild lift Supertech intake and exhaust valves over sized Nitto Head gasket Greddy Oil Pan Sump GKtech fan blade and adapter Koyo Radiator Borg Warner S362 SXE 6boost turbo manifold T4 divided  Turbosmart wastegate Pro-gate 50 lite ID1340x injectors Radium external surge tank Walbro 450 fuel pumps x2   All Parts in hand and awaiting my turn in line at the shop!
