Anyone here taken the front bar of a R33 series 2 GTST?
I am planning on starting to fit my FMIC on the weekend and just wondering if there is anything i should know prior to removing the front bar.
Do the headlights need to be removed to undo the bar?
How many bolts hold the bar in place and where are they located?
Thanks all
:P
https://www.sau.com.au/forums/topic/761-removing-the-front-bar-on-r33-sii/
Nick,
-First pull out the grille (5 plugs)
-below the grille there's three scrivets that hold the bar to the metal subframe, there's also one underneath the centre scrivet, just behind the number plate
-Behind the plastic inner wheel arch guard there's two screws either side which hold the sides of the bar to the front of the guards.
-The headlights don't need to come out
-Don't forget to disconnect the fog lights/blinkers
-It should come straight off.
The bar is easily cut with a jigsaw with a metal blade if the back of the bar needs to be cut forward to fit an FMIC in. I'm pulling mine off this weekend to check the my crash repairers handywork and try and line things up a bit better.
Ed
EDS: thanks for the info.... just what i was after :)
My cooler is 600 X 300 X 75 - have you fitted one to your car yet?
Im hoping to have the piping this week so I can start fitting
Jimbo: i will get some pics for you while i install if you like :)
Nick,
I had a Hyperflow FMIC the same size you've got in about this time last year, but had to pull it out cause it made the motor boil sitting in traffic in early september:(
The mods I had to make were cutting a hole for the pipework under the washer bottle and modifying the front of the chassis rail with a hammer:D
Ed
If I was moving over 70kph in any heat I'd have no problem, but once I was sitting in traffic, the temp almost went off the scale!
The intake air going through an FMIC is cooler for sure, but being a heat exchanger the air coming in the front of the car gets heated, then hits the air-con, gets heated further, by that time the radiator's got no hope.
Most people don't have any trouble at all. Maybe I had one of the thermo's wired up backwards?:uh-huh:
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
