plex action tonite
quote:
Originally posted by macka
It will only take a couple of beers then your done
From now on i shall refer work time in beer hours :)
Altho I recomend with work that takes more than 4 beer hours 2 lemonades to help u think straighteeeeeer before attempting another 4 beer hours :)
  • Replies 48
Kym,
If it takes longer than a six pack then give us a call and me and Macka willl put a cartons worth of hours into gapping your plugs. 2 beers to change, 10 beers to discuus how well we did the job.
If it's too much hassle, then buy a Greddy manifold, you can then re-gap them in 15mins, only cost $1500.
See'ya:burnout:
Hi Hicks,
I know about 5 different people that will make custom plenum's for you, just depends on what you want, and how much your willing to pay. Some of the custom jobs look excellent, and will be significantly cheaper than mine.
See'ya:burnout:
Originally posted by GTS-t VSPEC
Hi Hicks,
See'ya:burnout:
Hard to beat $1400AUS tho for the fantastic quality of the g-reddy plenum. Taka's pricing.
The G-Reddy plenum is very well designed, but that is not to say that you can't have something better than factory for a cheaper price. The plenum is going to provide very little in way of top end power if your still using the factory turbo. It does provide extra torque, and due to less piping the pressure drop is minimised. The major benefits in terms of power is when using a larger turbo, as the factory manifold is quite restrictive.
The G-Reddy plenum has alot of aditional metal left for port matching if you want to maximise the flow.
See'ya:burnout:
See'ya:burnout:
I thought the 90mm throttle body caused some bottom end problems (idle at over 1000rpm etc), this could be fixed by machining up some sleaves to fit inside the throttle body to act as a choke sleave does on webber IDA carby's.
Rev210,
Yes the larger throttle body does cause it to idle a bit higher, but this is of little concern, it still provides very good throttle response so I won't bother to adjust it. The Infiniti throttle body is a direct bolt on for the Greddy plenum, therefore this would provide a better idle for the car, but they are still quite difficult to find.
See'ya:burnout:
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
