on my RB20DET as I was removing a few of the camshaft caps and the bolts were very tight in the cap, i.e. I couldn't pull them out, so I had to try and remove them so I could clean the shank up other wise torque settings would have been very wrong :wack: (so it was not the tread that was tight, but the shank welded to the inside of the cap)
I soaked the bolts for about 5 days with wd40 and tried heat and everything, i was told to just undo them and they should be fine, well there are not fine the caps are twised :eek: so you have idea of how tight they were griping.
I had to pull the bolts out from the caps with a hydralic puller, they were stuck solid, i don't know how i undid them in the first place :chairshot
Is this common problem?
I had to really go at them to remove the caps, and its damaged the caps only, can these be replaced? i've been told that that i can't and the engine is scrap :eek:
how do i go about replacing them, there is 4 caps on the inlet cam thats gone :P
I'm so hoping that the head is not scrap.
do i need to have them bored to fit to my head?? can new caps be bought from nissan?
Any help appreciated
https://www.sau.com.au/forums/topic/76178-cam-shaft-caps-help/
The caps are machined (line-bored) as part of manufacture of the head and the bad news is they aren't available separately as spare part. If they're twisted as bad as you say then I'm afraid your up for another head.
The reason the bolts stick is that crap (mainly carbonised oil residue) build up between the shank of the bolt and the inside of the cap. When you try to undo the bolt the crap basically jams the bolt solid in the cap.
Could i not get some caps off another engine and get them line bored too the rest of them?
Yes that's possible...if you were a bit closer I have a head there you could have for free.
Edit: get some quotes first....you might find the machining will be more expensive than sourcing a secondhand head.
**bangs head up wall** thanx for the kind offer dude :cheers:
Its so hard to get parts for the RB20's over in the uk, totaly sucks.
I'm just glad i didn't send the head of before i made this error, one thing is scraping a head, scraping a ported and polished head is just stupid :)
I may send the head off to Abbey Motorsport (uk) tomorrow and see if they can't do something with it.
If it costs me £500 it would be cheaper then getting a second hand head.
My dead mint head :cheers: R.I.P
Well you might be lucky and they can do something with it. If the worst comes to worst let me know and I can ship you over some spare caps from this other head as replacements (you pay shipping, of course :) ). But you'd still have to have the bores machined/honed to suit.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
