but they sit open at idle (sucking in air AFTER the afm) so you can't vent them directly to atmosphere (learnt that the hard way)... they suck air in at idle causing stalling and rough as guts idle.
mine had an adapter kit put on them from the previous owner in japan. they vent to atmo and cant suck in any air :cheers:
so you just wanted sound?
anyway,
shaqrx3 - factory bovs are probably the best setup you will get.
but if you must upgrade and want sound, the single greddy type R is fine. it is huge and it will flow more than you will ever make..
Let me know when you want to sell your stock ones.
mine had an adapter kit put on them from the previous owner in japan. they vent to atmo and cant suck in any air ;)
yes they sit open at idle, which makes tunning a hell of alot easyer.
ask any one that tunes gtrs with AFM's. if you have bigger than stock turbos or BB turbos its hard to get the idle right with an aftermarked BOV.
i had that problem when i got the new turbos on mine, they couldnt get the idle right, because the BB turbos are still spinning damm quick after a bit of wide open throttle.
i also see it as helping the turbos as well, the plumb back system flows air after the intercooler back into the intake. so its breathing in cooler air :)
just my 2c anyway.
anyone know where i can get stockies? ive got blitz one and theyre huge...but then again the BOVs are placed where most cops wouldn't look
They pop up every now and then when rice.. err.. people replace the stockers with aftermarket ones. Just keep an eye on the forsale section.
Lucien.
Lucien.
yer, the for sale forum has then come by often enough for a few people every month or two etc.
But most people keep them i think as they know they are arite
True, but given the prices on NS (as low as $150 for a "hybrid" copy FMIC) I doubt there is going to be many used ones much lower on here :D
LW.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
