I will post here cos u can't attach pics to a PM.
You can have it for $40 if you want it - I think it cost me about $60 to get made up.
Pics attached - the flange bolt holes are at a 45 degree angle to each other .... not sure if this is normal, but you would want to check. I hope the pics show what I mean.
I am in Northgate fyi
Sorry, it looks like the sale is goin to Nightcrawler. But, yeah the flanges are meant to be set at 45degrees of each other on the cat. It should be a direct fit to your standard or aftermarket exhaust, provided its not a custom one. In the unlikely event it doesn't fit it only cost around $15 for Profix to knock out & re-weld flanges to align with exhaust.
ok...it seems the flanges on my cat apperar to be the same as your replacement pipe nightcrawler. Can u pm me your number so i can pick it up?
I need it tonight as my car goes into shauns tomorrow morning for a tune :cheers:
My cat is roughly 320mm long too...is that about the same as your pipe?
Northgate aint that far from me either...in near tea tree gully.
the pipe is excatly 342mm long from tip to tip - I am sure that is close enough!
I just tried to ring your mobile, but there was no answer. I'll PM u my phone number now.
well, had the new pipe fitted, and exhaust put on. All sounded sweet.
Then had the car put on the dyno where shaun started to give the car a tune to see what she could get.....
Made absolutley SFA difference....the car makes about 133 odd rwkw last time i had it tuned before it started to struggle to make power.Now the top end is better, and it makes a little more power but she struggles like hell.
It topped out at roughly 145odd rkwk then didnt make any more. :) Needs to go back to Shauns in a week or two for some problem solving. Might be cam timing is off, or something stupid like a boost leak.....who knows :(
Im soooo pissed....but the car does sound very nice with its "free flowing cat" now :cheers:
is this power figures for your RB31DET? i'm presuming your engine is fully standard aswell as your turbo? how different is yours to joel's?
Yes its my rb31det.
My engine is built to the exact same specs as Joels. (they were built side by side :) )
Turbo is a rb20det highflow jobbie (not done by me, but previous owner of the car).
My engine only has a few bits like rb20det oil pump (joel used rb25det) bigger fuel system (550cc, 044) and q45 afm/pod. Other than that they are identical.
I had some STR cam gears fitted when i had the motor installed, and Shaun reckons they may be a tooth out. :( I dunno myself, but it has to go back to get it all sorted in a week or two.
Dont worry about it Maxx, we were justy finishing as Joel went to leave....it wasnt gunna make any more power yesterday unfortunatly :(
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
