I will post here cos u can't attach pics to a PM.
You can have it for $40 if you want it - I think it cost me about $60 to get made up.
Pics attached - the flange bolt holes are at a 45 degree angle to each other .... not sure if this is normal, but you would want to check. I hope the pics show what I mean.
I am in Northgate fyi
Sorry, it looks like the sale is goin to Nightcrawler. But, yeah the flanges are meant to be set at 45degrees of each other on the cat. It should be a direct fit to your standard or aftermarket exhaust, provided its not a custom one. In the unlikely event it doesn't fit it only cost around $15 for Profix to knock out & re-weld flanges to align with exhaust.
ok...it seems the flanges on my cat apperar to be the same as your replacement pipe nightcrawler. Can u pm me your number so i can pick it up?
I need it tonight as my car goes into shauns tomorrow morning for a tune :cheers:
My cat is roughly 320mm long too...is that about the same as your pipe?
Northgate aint that far from me either...in near tea tree gully.
the pipe is excatly 342mm long from tip to tip - I am sure that is close enough!
I just tried to ring your mobile, but there was no answer. I'll PM u my phone number now.
well, had the new pipe fitted, and exhaust put on. All sounded sweet.
Then had the car put on the dyno where shaun started to give the car a tune to see what she could get.....
Made absolutley SFA difference....the car makes about 133 odd rwkw last time i had it tuned before it started to struggle to make power.Now the top end is better, and it makes a little more power but she struggles like hell.
It topped out at roughly 145odd rkwk then didnt make any more. :) Needs to go back to Shauns in a week or two for some problem solving. Might be cam timing is off, or something stupid like a boost leak.....who knows :(
Im soooo pissed....but the car does sound very nice with its "free flowing cat" now :cheers:
is this power figures for your RB31DET? i'm presuming your engine is fully standard aswell as your turbo? how different is yours to joel's?
Yes its my rb31det.
My engine is built to the exact same specs as Joels. (they were built side by side :) )
Turbo is a rb20det highflow jobbie (not done by me, but previous owner of the car).
My engine only has a few bits like rb20det oil pump (joel used rb25det) bigger fuel system (550cc, 044) and q45 afm/pod. Other than that they are identical.
I had some STR cam gears fitted when i had the motor installed, and Shaun reckons they may be a tooth out. :( I dunno myself, but it has to go back to get it all sorted in a week or two.
Dont worry about it Maxx, we were justy finishing as Joel went to leave....it wasnt gunna make any more power yesterday unfortunatly :(
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
