Including 3" exhaust, coilovers, 300km dash, complete engine ( loom, ecu, afm etc ) and gearbox, momo wheel and more
email [email protected]
Brisbane
Hi - I'm chasing the console area where the gearlever boot is attached - If you have one please email me "[email protected]" or 0403829350
Thanks
hi i'm after the plastic lining which is up inside the front wheel arches, its the front half ofthis plastic lining and has a vent style thingo cut into it to ventilate the brakes or sumthin ??? need tem for both sides, preferrably with screws aswell
cheers
I'm chasing gearbox, tailshaft, gearlever, centre console, manual instrument cluster,pedal box, clutch cyls and line, flywheel. Basically everything to convert auto to manual. How much?
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
