At last Pics and i got my New SKYLINE GOTTA GET P's B4 LAW NOW
Sweet as. Congrats !! Now look after it, and don't end up a statistic :P Go do a few skid-pan days under tuition. Great way to learn about your car and yourself ( and cut lose with a big grin ) :thumbsup:
BTW My first car was a Fiat 131 with no brakes or head gasket for $300.
( Times they are a changing !!! )
  • Replies 45
i loved my Na siliva i spead 4k on Mod and it was still slow and boring i need some boost i i cut my loser and sold it then i found the skyline it was so lucky i found it so cheap and in good nick
Now i stress every day about my P test
No offence but how would an L plater be able to tell if a car was "too slow" after spending $4k on mods on it? Theres more to driving than accelerating in a straight line - such as learning not to stall the car first like you admitted to doing in your first post :confused:
i don't stall it any more i drive it smooth and safe
Silvia was auto and boring and slow and loud and i didn't want it any more R33 has alsome Brakes handling Power manual air con everything i cound want
I am happy with it
I am happy with it
fair enough - you certainly seem to have the right attitude unlike a lot of clueless P platers.
nice car - i like the white skylines, mmm white wheels
i been driving and i worked out Fuel is eatn with boosting so i don't think i will b doing it much
alsome car i love it even outa boost its still sits and drive great thanks for all the help SAU
Looking forward to joining in on track day dyno days and cruises :D YAY P's
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
