  • Replies 125
Originally posted by GooGZ
then yang dont count... as you can clearly see here he certainly is not ashamed to pose for the camera with his hair out of wack after being in the water... no insecurity here. no westsiiiyyide.
:D
shit.... does anyone notice yang's legs (excuse me for noticing yang) but shit....... did someone photoshopped them or do they come stock silky & shiney like that??????????
fark im jealous hahahahha
He sandblasts, linishes and polishes them every night to maintain a mirror-like finish and enviable lustre.
hey helen, what hair yang lacks in on his legs is made up on his back and his ass....so i've been told! :D
Originally posted by URMINE
hahhahaha my ass she did :D i own everyone :)
see u gotta trick these "Ladies" into thinking they win.. :(
haha ive got a feeling that Paul likes the feeling of imminent death or sword slashing pain... either way, you will get both !
tis its not wat paul thinks that the ladies think but wat everyone saw!!! hahah
Teamwestside? franks.... ALL u have to do is demonstrate your precarious sexual insecurities like the other guyz here or isn't it obvious enough?
yang shall pass easily cos he already wears an ear-ring, minh and d other homos here will definately take him under their wing!
for you franks, just kept smiling and MORE of those 'i am taking a professional car photo' bum crauches!!   haha
meanwhile... my state of mind is quite forseeably clear... i AM not a butch!
ahhhhh ... "bum crouch" you mean like this one Helen!?!?!?!?!!?
:shake:
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
