***FOUND!!! 666DAN Dark Blue R34 Coupe***
umm.. have you told police that it might have those plates on it? if these guys really are that dumb, and the plate 584IPT is actually registered to them, ask for the police to run a check to see whos name its in and what car they drive, it's a small chance, but hey it can't hurt.
  • Replies 124
these plates could have been reported stolen to the police off another car and the police told "dan" that the plates have been reported stolen and maybe on his car. (from around the same area that his car was taken).
Will keep a look out also. I did see a Dark Blu R34 headed South along Gympie Rd Kedron last week around 4:45pm. Don't know if it was yours or not was in far left lane, light was fading and it was moving pretty quick. Just down from the Dept of Emergency Services building where i work.
umm, it was stolen this week mate
That was me though
Well if they are stupid enough to keep driving it, and just change the plates, then they could well be stupid enough to go down BWCP or at least head down that way. So eyes will be out for sure.
Sorry to hear mate....but which side of Brisbane was it stolen from???
Coz I almost had my R33 stolen the other nite when I leave my car outside my house....lucky my dogs keep barking then wake me up....I jumped into the car and chased them and called the police as well....It was a group of fuc*head driving a old Ford shit-box....and finally the policeS stopped them on the ipswich road near red bank plaze...
Fu*K those asshole who cant afford one but want to steal one!
try checking out or letting the wreckers or jap parts ppl know to let you know if anyonne comes in tryin to sell them R34 Parts??? badluck n sorry to hear that .. hope u find it soon !! will keep an eye out
Car has been located by a forum member buying parts, waiting to get the info to pass onto the police.
good to hear dan. hope ya lead turns out to be a true 1. maybe not the best idea to post up yet until the cops are on to it bcoz they mite read this.
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
