hey guys just a Q
it think my AAC valve is stuffed
i was driving for about 5 min all good the pulled up at the lights and was idleing bout 2000rpm
so i drove home and checked everything all is good but when i pulled off the electrical clip to the AAC valve she idled normall
my Q is can i drive the car with the AAC valve not conected or does it HAVE to be connected till i get a new one???
cheers
matt
https://www.sau.com.au/forums/topic/76317-aac-valve/
  • Replies 43
yeah thats like me irratic idle when conected
as for getting it off i almost striped the screw (stupid screws all should be bolts) but stoped before i stripped the head so im with you how do you get it off????
are there any tricks of the trade?
and as soon as the son of a biatch comes out im replacing them with hex bolts that will teach them
also i spoke to a auto elect round the corner he said it will be fine to drive without it conected the only thing its for is Air Con Ect....
also the only effect is that fuel economy will suffer (in his words "by a bees dick thats all") so all is good ill leave it disconnected cuz i dont have AIR CON and like i care bout economy i moddifyied it for a reason to go hard not to ***** foot around and cry bout fuel prices
cheers
matt
https://www.sau.com.au/forums/topic/76317-aac-valve/#findComment-1399349
AFAIK, they ARE bolts. And they're usually not done up all that tight.
It should be easy enough to remove the AAC, strip it down, clean it up, re-assemble and re-install.
https://www.sau.com.au/forums/topic/76317-aac-valve/#findComment-1399903
gotta agree with blind_elk
4 bolts, in the back, whole unit comes out, clean it all out, sometimes the spring can move around inside, you can flick the resin out end, and unscrew the the brass nut in there, to remove the spring , i pulled mine out retenstioned it a little, and reset it, seal the cap with sickaflex or araldite or so
https://www.sau.com.au/forums/topic/76317-aac-valve/#findComment-1399998
ohhh was going to pull just the cylinder shaped part off where there is only screw bolts holding it on so if i pull the whole unit off do i need to get a gasket or can i use just gasket paper to make a new one?
https://www.sau.com.au/forums/topic/76317-aac-valve/#findComment-1400010
pull off the AAC valve (the four bolts 10mm socket) there will be a gasket there all should come off without breaking the gasket, once off get some carby cleaner or brake cleaner and spray into any visible holes try to seal some off with your fingers adn shake it round.
What you are trying to do is free up the plunger that has been jamed in carbon and oil and all the other shit that enters the inlet
then replace
but this did not work for me i think i have a prob in the wiriing which is holdinig it open but i dont know just disconnected it then set the base idle
cuz thats what the service manual says for setting idle
Pull off conector to AAC valve then turn screw to set idle!!
https://www.sau.com.au/forums/topic/76317-aac-valve/#findComment-1407102
Cheers mate, greatly appreciated. Yeh I read the bit about adjusting the base idle with the AAC wiring off, but it did nothing, I think it must be too full of crap inside so I will clean it tonight and hopefully I will get a regular idle of 600 instead the 1500-2000-3000 I have had lately. I will let you guys know how it goes.
https://www.sau.com.au/forums/topic/76317-aac-valve/#findComment-1407132
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
