  • Replies 43
Check the air reg down where the injectors are.That may be dirty inside aswell.There is 2 10mm bolts holding it down and 2 fat hose's each side.
__________________
is it square shaped type off thing?
can anyone think off a reason why it will idle high when AAC valve conected
but idles normally when its not???
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1408971
It still idles high even when I disconnect it... I admit it does drop, but not a lot and it still idles way too high and now this hunting thing is driving me mad, I will sit at the lights and it will bounce between 1000 and 2000, bloody irritating!!
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1409000
Okay, I disassembled and reassembled my AAC valve, didnt do anything, Im in the process of putting the Air regulator back in, just waiting for gasket goop to dry. I think this might do the trick as the spring wasnt under any tension which would suggest that the plate couldnt move due to being in the incorrect position. I will post later to confirm If it worked
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1409955
Well the Air regulator is back in and the car idles around 1000 and stays there, no more hunting for me!! I gotta say it was pretty easy and you can't really go wrong with the internals of the regulator, they only go in one way.. I'm happy with the result.
eXc your guide was how I started out repairing the valve, great one mate. Cheers
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1410308
i sorted out most of my prob
found that the turbo smart blow off valve is most likely after i dissconnected it i had allmost no drop in idle at all and never stalled
connected it and again after pulling up at light ect.. it would stall and drop really low idle
i opened the bonnet and reved the car and watched the BOV found that it was sucking in air because the valve would not fully shut
so now its disconnected
maybe the rest of the prob is the fuel pump
as silvia pumps operate with a ground swith that at idle it drops the current to the pump so low that it cant operate properly (i have GTR pump)
so on the weekend ill find the earth wire from the pump and run my own bigger gauge earth to a earth point in the boot
hopefully it fixes the prob or ill have to run a new cable from the switch and new relay also with same gauge wire
hope it works
cheers
matt
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1412432
timmy c
The air regulator has two bolts holding it to the intake manifiold, get those out and two hoses and connector and your on your way, you can take more hoses off to give yourself more working space as well. eXc's tutorial is good try use that, getting it out was the hardest part. It will require a little patience, but will come out. The screws on the air regulator are tough ones, but I sprayed them with a bit of lubricant and used a quality phillips screwdriver head and just moved it a little at a time, also helps if you push down on the screw to stop it stripping the head, I thought they wouldnt come out, but with a bit of patience(again) they came. If you got anymore questions post away
Good luck mate.
blackrb20silvia let us know how the pump goes
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1412973
Hey guys,
Took my regulator apart today. Is the spring supposed to hold the rotating thing shut entirely? Mine is half open? It wasn't dirty at all either so maybe its the AAC instead....
I put it all back together and now the idle is high :D its idling at around 1500. Before it was fine, I don't think i've changed anything. Its shit!
Anyone got any ideas?
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1415867
I played with the water temp correction(wrote down what setting it had first so I could set it back if need be) table and thats why it revs high when cold.I got it idleing at 1000rpm when stone cold but it was rough.
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1416251
Yeah I fixed the problem, I put in a stronger spring then factory. It idles up fine but now when warm it drops straight down no messing about. :(
It still hasn't fixed my start up issue though. When I start the car in the morning I have to give it some throttle or it sits around 200RPM and coughs and dies.
The guide is good but the pics don't works anymore.!
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1417068
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
