I,ve gone about as far as I can with this one , so time for a new toy :cheers:
376rwhp on Vortex pump fuel!
94 R33 Skyline Sedan
RB26dett ,
Hi-flowed Steel wheeled twin turbos (T28 exhausts)
Split Gate dump pipes & custom 3" exhaust
Twin K&N Intakes
Walbro fuel pump
GReddy Adj. Cam Gears
FMIC
Turbosmart Vee Port BOV
Apexi RSM
FETT turbo timer
RE40 auto box (modded) with 2 torque converters (1 stock & 1 3000rpm Hi Stall)
Redline Fluids in everyrthing , eng , box (Racing ATF) & diff
Wolf 3D V4+
Ziets Rims , 8 1/2" front 245/40/17 , 9 1/2" rear 275/40/17
& the list goes on
This is a truly awesome SLEEPER with over 20k thrown at it , & it IS licenced in WA as is!
$26 000
I can arrange finance & insurance if needed :)
No dreamers Please
Call Troy 0407 445 155
Photo's
https://www.sau.com.au/forums/topic/76337-rb26-powered-r33-4-door-376rwhp/
Update...
Have just aquired a full manual conversion for this as well.
ie: 5spd from RB25det
600hp sinlge plate clutch
pedal box
clutch cylinder
centre console
& instrument cluster ( auto 1 has PRND21 on it)
We can negotiate price as a manual if you want.
* Note , the car will be at Hyperdrive in Malaga WA on saturday the 18th for the dyno comp  if anyone wants to take a look :(
After driving the 200kms to Perth & jumping straight onto the dyno , the car still pulled 358.9 rwhp! Quite consistant that :)
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
