I've got an adjustable exhaust cam gear, set to 4' retard.
I don't see the stock ECU having too much trouble still running the show but some form of ECU control would see maximum results.
I'm going off memory here....... it was 215rwkw before the gear & ~224rwkw after, however this was when I still had my Unichip/stock ECU combo & my AFM was maxing out very badly! It was a peak of ~224 but with huge dips in the power curve :) With a Z32 AFM or a MAP based ECU bigger gains "could" be achieved.
I'd say a 10rwkw (peak power) gain is about what you should expect. But you'll probably lose a few kw down low.
Originally posted by rev210
You still haven't put that cement in the boot yet have you? I told you put the cement in the boot , so do it NOW!:)
:lol: :D Don't need the cement anymore! I've got traction in the form of 255/40/17 RE540S's. They're no Nitto or BFG street drag radial but they sure are an improvement on the Falkens I had :uh-huh: It still will w/spin a touch but nothing like it did before!!!
rev210,
With exhaust gear alone I'd expect 8-10rwkw, with inlet gear about 5rwkW more, but you'll loose the NVCS. I think the settings are 2deg advance inlet, 4deg retard exhaust. Will make more difference with bigger turbo or cams, but still a decent increase for the price.
Which brand were you thinking? JustJap can get the OS Giken ones, $300 each.
See'ya:burnout:
QUOTE]Originally posted by macka
whatsisname thats a nice 1/4 mile time on that boost!
were u using the stickys to get the 2.1 60ft?
Thanks mate. Believe it or not I actually ran those numbers on my old Falken ZIEX ZE502's (255/40/17). With the extra 40+rwkw & the sticky 540's I'm hoping for @ least mid/high 12's.
I'd like to 60' in the 1.9-2.0 range with a mild launch.
Back to the topic of cam gears...... As GTS-t VSPEC mentioned, bigger gains will be had on engines with turbo &/or cam upgrades.
If anyone is wondering how the RB25DET feels minus NVCS, just disconnect the elec connector to the solenoid & go for a drive! Obviously if you're planning on a complete cam swap then a decent compromise minus NVCS can be found.
whatsisname,
My plan is to loose the NVCS, but I will be doing cams and bigger turbo, for light to mild tunes then keeping the NVCS makes sense.
Is that the factory turbo your running? Very impressive times, the R rated tyres should gain you a couple of tenths.
See'ya:burnout:
Originally posted by GTS-t VSPEC
rev210,
See'ya:burnout:
Probably get HKS from nengun for $180. I noticed the debate over cam gears and I think the bagging people were giving the HKS gears was bollocks. They use their own gears on their drag cars and I've yet to hear of a propper example of a failure and a reason related to actual design/manufacture (one that makes sense). I'll do this along with the light underdriven front pulley when I do the timing belt.
I don't think on most cars you'll have a problem with the HKS gears, but even sub-zero who sell them said they weren't as good at the other brands. Nengun has them cheap, but by the time you add freight I can buy them just as cheap here. The HKS drag cars are hardly going to use anyone elses gears, even if they were better, but they might get replaced frequently. I think the HKS ones will be fine, I'll most likely use them on mine, if they break then I wont use them again, simple as that.
See'ya:burnout:
whatsisname,
See'ya:burnout:
I've seen a few GTS25t owners that have ditched the NVCS in favour of aftermarket cams & adjustable gears, all with good results. These cars all had bigger turbos & a host of other modifications. The JMS 300+rwkw GTS25t (standard internals) is one of these examples. It uses the earlier non-NVCS RB25DE inlet cam.
My car has a T3/T4. It's not a high flow of the standard turbo but a total replacement with bigger housings. I'm unsure of the exact specs?
The 1/4 #'s in my sig' are pre..... R tyres, Microtech LT12, custom inlet pipe work (nil AFM), cam gear & a few other minor things. No major changes but it all adds up. Oh yeah & some very good tuning too :mad:
whatsisname,
Yes I was told to loose the NVCS for higher horsepower applications. I will be running the GT30 turbo, so I expect some good gains with the cams and cam gears.
Is the Microtech LT12 the new plug'n'play, what do you think of it?
Sounds like a nice setup, I got rid of my AFM aswell, haven't noticed any loss of fuel consumption, cause it was pretty shit before.
See'ya:burnout:
GTS-t VSPEC,
The LT12 is one of Microtech's new laptop programmable ECU's that can be configured for the GTS25t. It comes loaded with base maps to suit (like the PFC) & then plugs straight into the factory loom. There's one extra sensor that can be installed for total functionality (intake temp) but it's very simple & taps into the existing AFM wiring.
I'm really happy with my LT12 :mad: The engine is responsive regardless of throttle position or rev range, it idles nicely, makes good power & hasn't cost me all that much to get it installed & tuned. Fuel economy I don't take much notice of but it's @ least on par with the stock ECU.
whatsisname,
Thanks for the info, it's good to see that the engine managment systems are improving and becoming competitive in price and functionality. I'm using the new Wolf, and have been equally impressed with it.
See'ya:burnout:
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
