Bottom end strength?
Hey all, i searched and searched and didnt find much. I have an r33 Rb25det and i just reached 300 kw on the dyno yesterday after the next stage of my mods. Although it was only on 18 psi i am worried that i have pushed the standard internals as far as they will go...Without breakage.
What kinda power and boost is everyone running on standard internals?
Or does anyone know how much the bottom end will handle?(approx 90,000kms)
dont know for sure but things i have read you shouldnt push them past 300 rwkws on a standard bottom end . Iam in the hunt for those sort of figures and have just about finished my rebuild( flogged out valve guide) with fordged pistons and rb 26 rods so i hope it will be strong. Congrats on the figures to thats great.
Sydneykid Rule of Thumb (yes another one) for an unopened RB25DET is 450 bhp, that's ~280 rwkw. So you are already past where I would start looking for signs of distress.:)
Sydneykid Rule of Thumb (yes another one) for an unopened RB25DET is 450 bhp, that's ~280 rwkw.  So you are already past where I would start looking for signs of distress.:cheers:
300kw is only 402BHP
450BHP = 335.5kw
Over the years we have developed a standard around here.....
BHP = Brake Horsepower, which can only be measured at the crank, on an engine dyno if you like.
RWKW = Rear Wheel Kilowatts, as measured on roller dyno (Dyno Dynamics being the most popular in Australia)
BHP / 1.34 - losses = RWKW
:cheers:
PS; it is much easier if everyone uses the same language.
SK:- What usually goes wrong if you go  over your suggested power limit(280rwkw)?
What do you suggest are the most important parts to strengthen when aiming for 350RWKW??
Things I have seen fail;
Piston ring land
Piston crown
Head gasket
Little end bearings
Conrod bolts
Big end bearings
Main bearings
Exhaust valve and seat
The #1 part is pistons, #2 is conrod bolts, #3 is the conrods themselves. Head gasket can be an issue on older engines, head studs are a good solution. Upgrading the bearing material is important and main bearing studs are worthwhile.
Actually the only thing I have not seen fail is the crank, they are blooody strong suckers.
Hope that helps some more:cheers:
SK- What bearings do you use, and what studs do you use for the main bearing girdle?
We used to use Clevites but they must have done an exclusive deal with some Jap Tuning House, so we now use ACL Race Series, great results so far.
We only use ARP studs, never had a problem with an ARP product.
:cheers:
 Share
