1400r , yes you are right on ,that tested the car again today and we were getting that weird wooshing sound as the impeller starts to go the wrong way cant put the old turbo back on without going to a lot of expence remember most stuff on the turbo side of things has been custom fitted but where looking at another turbo at the moment a gt30 the tuner and turbo guy are talking about it now on what to run.
Cerealkiller sorry i dont no the AFR its running but the cam timing is set for standard for the time being till the problem is sorted
Chris32 havnt chattered to you for a bit but yes thought of that because it had eratic idling to but proved not to be the case turner did the figgers on the flows and its running 90% air flow effeciency on 18psi a boost but they recon the turbo's running outa puff as the cams are starting to work
GTST > i dont no the enough about the r33 turbo to commont on that and yes it drops straight down to near stock boost levels but in that 3000rpm range it woops arse
Thanks Peter
I have a hr31 gt passage with r32 rb20det with stock heads and bottem end with these mods:
- microtec ltx-8
- 550cc injectors
- hiflow turbo (no idea on specs except its a t3 housing)
- full 3" mandual bend exhaust with hiflow cat
- front mount cooler
Now it produced 198.8rwkw on 18 psi ill send anyone the dyno results just email me at davidperez@iprimus.com.au
So you have something wrong with that motor only producing 160kw
Cam timing is essential I think... Im fairly certain RB20DET Auto should be 20 degrees, not 10 or 15... I found my throttle response to be quite shit at 15 degrees, bumped it upto 20 and it ran smooth as :cheers:) My Cefiro is Manual now but use to be Auto, therefore perhaps the base timing in the ECU is different to the std Manual based ECU?
JK
In all fairness, intercooler ineffiecency, incorrect cam timing, and retarded ignition are not going to loose 90rwkw which this should be making.. Unless they are all completley wrong, i would say that your tuner has it right that its a mis-matched turbo and is surging under boost. Would be great to hear the results after the gt30 has been fitted.
Cam timing will loose 90rwkw easily.
My RB30DET with the stock RB20DET turbo with 9psi made 176rwkw.
On the same dyno and a RB30DET that was built at the same time as mine only made 125rwkw with 14psi and a t3/4 spec RB20DET turbo highflow.
Looking at his cas sensor, 15degree's has the cas sensor almost in its fully retarded postion. So the cam timing IS way out.
It has yet to be fixed but will be soon, I'm keen to see the results.
I would expect 220rwkw maybe 240rwkw if we are lucky. :)
my rb20t was also disapointing. mods are walbro 500hp fuel pump, malpassi black 2:1 regulator, hybrid intercooler kit, custom t3-t4 turbo from dyna torque, turbo back 3 inch exhaust, wolf 3d v4 tuned at rotamotive, k@n 4 inch diameter air filter. it made 189rwkw
(221hp) at 18.5 psi. ignition was said to be breaking down. since then ive closed spark plug gap and up graded to splitfire coils, now waiting to put it back on dyno. will be going to just engine managemant at moorebank, seen em do great stuff
i ahve a feeling its the timing aswell as my car is not performing as it should have been told that if the timing is set to base timing then it needs to be advanced to take advantage of the mods
it feels real gutsy till on boost at bout 5000rpm
wastold that an advance in timing would bring the boost lag down a bit
food for thought
cheers
matt
Hi Guys
Well as it stands at the moment the to4 is having a new inducer housing put on it as was deemed way to small decided not to go with the gt3040r as plotted to be way to laggy for an rb20 just waiting on the updated turbo at the moment so can be refitted then we will try tuning again. By the way anyone know of anyone else that might be good at tuning the wolf 3d for a skyline in sydney
Cheers Peter
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
