I am putting in my stereo and was wondering what size / shape speakers people had in the rear parcel shelf of their ceffies.
I got some ultra cheap 6 x 9 but noticed the holes in the metal ar not big enough for them. I dont really want to hack away at the metal to make them fit because the speakers are pretty crap anyway.
I reckon I could fit 6 inches into the whole and screw them into the parcel shelf.
Anyway could someone give me some guidance as to what you have put in there.
Thanks.
https://www.sau.com.au/forums/topic/76470-rear-speakers-in-cefiro/
Use spacers if you want to fit 6x9's.
Where can I get these spacers u speak of ??
Haha stock speakers. The guy that I got my car off gave me the front ones from my car :cheers: the cone isnt even attched to the speaker its all ripped appart.
Dont get decent speakers for the rear dude :) Just get some really nice stuff for the front. Just some cheap coaxes would be fine for the rear. And I do belive 6inches fit the holes. But you should really use spacers, Im not sure if speakers would clear all the boot lid opening stuff.
get yourself a peice of 12mm mdf, make a template of the parcel shelf with carboard, adn cut out the mdf the same as the template (make sure you include the speaker holes too), screw the mdf on the parcel shelf. try and use some sound deadening on the bottom of the parcel shelf.might cost you $20 all up and you get awesome sound
  • 3 weeks later...
Hey dudes!!!
Sorry to hack up this old thread but am looking at putting in a very basic system into the ceffie soon. My 'retro' cassette double din head unit really doesnt cut it...lol....and the speakers are F&*Ked. I know some 6x9's are easily mount with a bit of mdf fitted or spacers but what size front speakers fit without any modification??? 4"? 5"? Just simply wanna but the speakers, fit em in and be done with it........ big doof doof need no apply here...lol :D
Cheers in advance guys!
Ando
i havent done the rears yet ....but will be putting in some big 6 x 9's .........
i put smaller sized 6 x 9's in the front and they sound really good ( needs a little more sound deadening. They are very fiddly trying to fit (making mdf mounts etc ...)
i would proabbly go 6's
get a reasonably cheap mp3 head unit ...e.g the kenwood or pioneer or jvc one for 250$ bucks.. or even cheaper if u like....
erm,
try like supercheap autos for the spacers if you're that keen,
but like, why bother getting 6x9s? they're out dated.
it's so difficult and expensive to get them sounding good, why you just get a 12" sub? more often than not they are surprisingly cheap, the cefiro has a huge boot to accomodate a nice box,
i can do you a good deal on a GREAT sub and amp packadge if you already have a decent headunit
and i mean GREAT, like genuine brand new less than half price gear, pm me if interested
Fronts no idea cos I fitted 6.5"
Rear I wouldn't bother with 6x9's unless you're not going to put in a sub.
I would recommend any speakers in the back are slanted forward not to bounce off the rear glass as much. If you slanted you could anything in there and my pick would be some average 6". I'm actually using the standard-ish carrozeria in there because rear fill isn't my concern. Sure it's a 4 seater but if you're in the back and want good sound get a walkman :P So in saying this you should consider if you're not expecting to entertain people in the back you don't bother with any and use the money on some decent fronts.
I highly recommend sound deadening and some decent sized front speakers with spacers.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
