Just to throw a spanner in the works - no . That car is hardly neat and on closer inspection would not be tidy . The boxy bits may cover silly sized wheels but did you note the front wheel offset ? , that thing would be bump steer city . There's no way you could get  ANY reasonable amount of positive caster into it without the tyres eating the arches .
The GRP A DR30's didn't look like that , and with the best of todays road tyres and suspension geometry findings you can do better . Ill take function over phat looks every time , function delivers lard does not .
Disco, Must you ruin everything??!!!! :)
Disco, Must you ruin everything??!!!! :D
Good call!!! But you have got to admit the man has got a point. For me the real pleasure of owning a hot car is driving it not looking at it, and when you are driving you dont really take that much notice of what the car looks like.
But disco you gotta admit it looks GOOOODD!
On the flip side, if you were going to spend all that $$$ on getting the car looking phat then hopefully you would have the sense to spend equally large amounts on getting the car to perform as it should.
With that in mind has anyone in Aus really developed a DR30's suspension.
ie wishbone, multilink (please forgive if question is stupid, I don't know shite)
Oh Yeah, I'm with stu_r30, whats going on with that front bar?
I wish I had a DR like THIS HERE imported for me rather then a dead stocker. I would have saved myself so much money.
Yeah but that would defeat the whole purpose of playing with cars and the satisfaction you get at the end of it...And lets face it, even if you got that car you'd still do shit to it, where does the modifying game end really????? Its one big viscious circle......
I know what ya mean but to start with a car like that would be so much better, already has built motor, after market comp and sus done. SO all ya have to do is improve on the base ya start with, rather then blow the amount money I have already just to get to the point where that car is at. That has got pretty much every thing that I am currently doing to my car minus a thing or 2. :uh-huh:
it all depends on your bank balance, patients and what you want as an end result.. with my car i have a list of things i want to do to get it to the point i'm very happy with but with each few weeks the list get bigger, more $$$, the list is at about $10,000 at the moment plus the $$$ i've spend.
On the flip side, if you were going to spend all that $$$ on getting the car looking phat then hopefully you would have the sense to spend equally large amounts on getting the car to perform as it should......etc
Yeah,I hear what the man's saying,but damn......looks at that thing! Mini Tomica racer!! :stupid: I do agree about function over form though.My last (decent) car was a dead stock looking Pintara,with the motor seen in my avatar. 100% Function ;)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
