Brand New: Pivot Gekko Gauges, In stock and Ready to ship
Come with Sensor and Stand, All in stock ready to ship.
Boost Gauge>> RRP: $330.00>> $280.00 shipped
Oil Pressure>> RRP: $440.00>> $340.00 shipped
Oil Temp>> RRP: $290.00>> $240.00 shipped
Water Temp>> RRP: $290.00>> $240.00 shipped
Vacuum Pressure> RRP: $325.00>> $270.00 shipped
F1 Tachometer>> RRP: $380.00>> $290.00 shipped
F0 Tachometer>> RRP: $380.00>> $310.00 shipped
Please PM us for a package price
**We will match the price if you find anywhere else cheaper, we got all in stock**
Checkout how accurate the pivot gauges are:
Tested on CIVIC EG6 : HERE
Tested on Z33: HERE
More information at: http://bt-revolution.com/Gekko%20Boost%20Gauge.htm
