Hey people,
A nice 93 gts-t is up for grabs:
- 4" HKS exhaust,
- Custom built brass button clutch,
- custom body kit,
- 18" RTG Shadows,
- aftermarket headlights,
- hybrid intercooler,
- pod filter,
- full respray,
- boost controller,
- boost gauge,
- turber timer,
- gearbox rebuilt 5mths ago,
- sports suspension,
- kenwood headunit & 6 cd stacker,
- sports steering wheel,
- aftermarket gearknob & handbrake,
- Alarm & immobiliser,
- serviced every 5000kms,
Comes with RWC.
Featured in last years semi final autosalon!
Call Mark on 0411 138 677
Price is $20,000.
* Price drop to $19000
need to sell urgently, need to get the drift car.
https://www.sau.com.au/forums/topic/76574-1993-gts-t-for-sale-victoria/
  • 3 weeks later...
Why did you post this (second post in this thread),
Very interested in this car. So you are asking for 19k now are you?
pm sent with details.
if you are the actual owner? Sounds a little sus. :confused:
PS: Since you asked; The asking price is high and if you need to sell it, a more realistic price would be about $14,000.
well first of all we just put that on there for a laugh nothing sus going on there.
and are u serious $14000 does it look like a for does it look I'll drop the price a bit more but I wont give it away thanx for your Input and just so u no Im not having a crack at u (Al)
thanx!
look i'm not trying to sell it in like a week and 14 are u serious I might as well give it away.
I have spent 8 on it in under a year now I dont expect to get my money back but I just think that is silly. Look Im dropping the price 2 18,000 but thats it the car is like brand new inside and out. I think thats a bargin and a half
I no for a fact that they are selling for more than that and I hate to say it but u boys aint exactly helping me sell my car sorry but I just thought Id point that out thanx for your input if u have anything else to say like that send me a pm thanx for all your input guys.
keep It sideways!!
from drift32.
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
