Gotta sell this to recover funds I am short after selling stuff for my mate, and need the $ to refund the buyers as it was not received
The TX4400 transceiver is Australian designed and built and is one of the most advanced UHF Citizen Band radios available.
The TX4400 combines the very latest in electronic hardware with the most up-to-date computer aided design and manufacturing techniques to produce an extremely versatile mobile radio with outstanding specifications, performance and a 2 year GME warranty.
The TX4400's DIN sized case allows it to be conveniently installed into a dashboard or console and its strong diecast aluminium chassis makes it the most robust transceiver of its kind. With just three rotary controls and five touch keys, the TX4400's extensive features are easy to operate.
One of the a major feature benefit to be added to the TX4400 is that the extra receive channels can now be User programmed into the transceiver via the front face. At any time the user can put the unit into a "Programming Mode" and activate any of the extra channels from 41 to 60. Once activated the user can set and store any frequency between 465 and 485Mhz. This can be changed or the channel deleted at any time after initially being set, and all from the front face controls. No computer connection or software required.
Great for listening to Cops/Fire/Ambulance etc!
Specifications Here
$300
https://www.sau.com.au/forums/topic/76581-gme-cb-scanner/
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
