hey, is there anyone living in Japan (Rezz etc) that would be willing to go to a parts yard, acquire me an R34GTT 4 door STOCK exhaust, and post/ship it to Australia? Since they are such a small value item (I have have seen them on Ebay for as little as $10), it is very restrictive to get one of the forum sponsors to bring it in, as they have to declare value and pay duties plus GST on the value + shipping cost. If it is a 'personal gift' it avoids such costs :mad:
Your problems gonna be size/weight. It might cost in the region of A$150 - 200 to get it to AU (by EMS or similar)... then theres the eeerm... $50 - 100 fee that I'd need to source an exhaust system then package and lug the thing down to the Post Office. It's not the type of thing you can just 'do on a casual Sunday arvo' you know? Can't you find one in AU? They must be a dime a dozen down there. Alternatively you could put it in a container full of other cars/parts and pay nothing, but I don't have a container going to AU anytime soon :D
Rezz, you would think there are some around, but I can't even find a 2 door one, let alone a 4 door one :D .... I have rang EVERY import yard, wrecker and compliance workshop in Adelaide, and a heap of places in Qld, NSW and Vic. Nothing. Nada. I'm getting a tad desperate. Well not quite desperate, but disconcerted at least. If you could get me one here for say $250 I would be happy with you keeping whatever profit you can make :mad: ..... and you would be helping a fellow SAU member - for which I would be eternally grateful!
On a side note, have any of you guys in Japan ever heard of the radio DJ Chris Glenn? He is originally from Adelaide, and his Japanese wife (originally from Nagoya) is sort of my adopted sister.
and the best rates I can get from a trader (like Slidewize Imports off SAU) is about $200 to get it to Australia, then $100 to freight from Melbourne to Adelaide. I just don't want to pay that much. Plus there is the issue with them sourcing one from Japan, which would normally be off Yahoo or Ebay, then have to pay internal Japan freight etc to get it to the shipping container.
checked it out - shipping of an exhaust by these guys is over $400 - sheesh!!! My whole car cost $1,200 to ship directly from Nagoya to Adelaide - wtf???
Yeah, $400 is by plane I'd imagine...
It *might* be $50 - 100 cheaper if you send it by ship, but then you'd have to wait 2 - 3 weeks for it to arrive, maybe more. But at the end of the day you're still paying at least $100 or more for the exhaust, then at least $200 odd dollars for shipping. Save yourself the hassle and drop $100 on a car dealer willing to let you 'borrow' their GT-T exhaust for a day or two... it's just for compliance isn't it?
there is not a single R34GTT for sale in SA that I know of, and I have already tried the hire or borrow line with interstate workshops. Hrrrrm - I will just have to keep on hunting :P Thanks anyhow Rezz.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
