Injector duty
KillerT,
Fitting the Malpassi is pretty straight forward, just need to choose an appropriate mounting location for it. I can post some pics of mine if you need a good layout and location of all of the lines. No you won't need any retune, the car should behave identically it just won't run out of pressurised fuel. I have mine set to about 30psi, you will need to increase this as your power increases, too ensure sufficient fuel pressure at all times.
Macka,
It looks like project, "Up boost", has been green lighted. Need the clutch before you give it more power?
See'ya:burnout:
about compression ,On my civic i was running a comp ratio of 10.4. With a t3 and 14psi ,that's on stock internals ,The key is tunning .higher comp just means less room for tunning mistakes.That's why i had to decomp it cause every1 was too scared to tune it (unless i sent it to the states where 600hp honda' run a comp of 11.4 with t66's on 20psi)so now with lower comp it makes it heaps better to tune but i lost a fair bit of power :mad:
If someone can tune it for u then do it but not without a good comp like a motec.
But on the other hand my civic has a almost perfect rod stroke ratio,im not to sure if skylines do or not .
I think Macka was already having difficulty with the tuning, therefore relying on the ROM might have been pushing it. It seems that the consensus is that he will have no problems at that boost level, so once he has the clutch don we will expect big things.
I would have thought any 600hp car would have used forged internals? I think the Skylines are under square for bore/stroke, hence the reason you have to rev them hard to get power.
See'ya:burnout:
Originally posted by KILLER-T
Ok so a Malpassi rise rate fuel regulator will help me.Are they hard to fit your self or am i going to have to put it on a dyno for a fuel remap
You will probably like to have a remap so you can get the fuel pressure setting right for the duty cycle you want.
If you put the rising rate on it will load up the fuel pump more, decreasing its maximum flow volume as the pressure is raised. I say the pump you fitted will do very well all the same with the power you have.
550's take the stain off the pump because you don't need anywhere near as much baseline fuel pressure as the stockies and therefore your fuel pump will live longer, having a lower duty cycle.
Rev210/KillerT,
In general unless your planning on raising the fuel pressure through the roof then it won't need retuning. The fuel pump won't be loaded up suffciently much to warrant this, none of the people that we have put it on bothered, and the cars run just fine.
See'ya:burnout:
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
