Garage cleanout,
R30 / L24E parts:
L24E standard computer
L24E bare EFI loom
R30 L/R headlights (both unchipped)
R30 L/R front indicators (one cracked, one A1)
L24E dizzy
L24E coil
Bosch external EFI pump (of EA Falcon, little use)
L24E block water inlet with 3 sensors
Prices neg, U pay freight, may be able to get low res (camera phone) pics if interested. All stuff was working when pulled from wreck, but will be sold as is where is.
machg
(Southern Tasmania)
https://www.sau.com.au/forums/topic/76595-r30-parts/
My R30s fuel pump has just shat itself.
Interested to read that you ran one from an EA falcon.
What other ones can you use on this model.?
L24E bare EFI loom
L24E dizzy
L24E coil
machg
(Southern Tasmania)
https://www.sau.com.au/forums/topic/76595-r30-parts/#findComment-1403930
Sorry about the delay in replying, the fuel pump mentioned was bought for another project. I think R30/L24E fuel pump might be located inside the fuel tank. Can't see why you wouldn't be able to plumb this pump to the fuel line that comes from the tank, and wire it using the wires that are attached to the factory fuel pump. Would be easier than replacing the factory pump (if its an in tank job). Any external EFI pump from a large car (for sufficient fuel pressure/flow) should be able to be used in this way.
machg
https://www.sau.com.au/forums/topic/76595-r30-parts/#findComment-1412880
