Does anyone know if any of the parts in the RB20 Head are compatible with anything else.
From what I've seen on Tomei web-site it looks like the Z32 VG30DE/TT and the RB20DE/T share the same Valve Springs
And the Valve guides for the Intake are the same RB20,25, and 26
Valve guides for the Exhaust are only the same with RB20,253
The Valve lifters seem to be the same with the RB20,25 and VG30DE/TT
According to JUN the Valve spring retainers are the same for the RB20 and the VG30DE/TT
This is not Head related but the Crank Bearing Cap Studs are the same RB20,25,&26
-So today i took my head down to the machine shop and he took a look at it and said that it doesn't seem like any of the valves were seating. LOTS of build up on my valves nasty nasty crap all over them
So if anyone has vavle seats or knows of USDM seats that are the same please let me know thanks
https://www.sau.com.au/forums/topic/76643-rb202526-valvetrain/
What I can tell you about RB valve train;
The RB20DET valves are not the same as any other RB. The combustion chambers are too small for RB25/26 sized valves.
The RB26DETT valve train has solid followers, RB20& RB25 have hydraulics. So you can't use bit out of one in the other. You have to swap the whole lot over. This is of no use to you as the valves won't fit anyway.
You can use RB26DETT valve springs in an RB20DET but you have to modify the spring seats in the cylinder head and the retainers. You also have to use shims to achieve the right seat pressure.
We always use genuine Nissan valve seat inserts, the part numbers are on FAST.
We find it is cheaper to throw bad RB20DET cylinder heads away and start with a good one. It is cheaper to buy a good used cylinder head and refurbish it, than buying the new parts from Nissan and then spending hours on it.
Hope that is of some small help:cheers:
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
