it's your brake lights trust me, i had the same problem when i switched to my funky-doo upspec lights,
the problem is as follows, in your brake lights there's two globes, one out of the 4 (2 lights =4globes) one out of the four will not be coming on when you brake, to figure this out you'll need to get someone to tap the brake while you look at it,
the problem with mine was that the connection of the globe itself had corroded so i scratched it on a brick (like a dodgy balinese mechanic) then i had no troubles whatsoever
hope that helps
bali mechanics are the best, they can fabricate ANYTHING out of sand,
next time you're admiring an hour glass, spending a day at the beach, or making brick to build a house, try to think where we'd be without....... .. .. . SAND
