I will be installing a FMIC soon but i am not too sure what to do about the stock bar that will block airflow.
What have others done to this type of bar?
Would it be better to buy a new front end or chop the one i have?
Here is a pic anyway
The bar is in the centre where the number plate hangs off
https://www.sau.com.au/forums/topic/76651-front-bar-blocking-intercooler/
chop chop the original its easy and cut it out neatly and it looks fine ;)
heres a piccy of my stagea bumper i chopped which was fully covered in the centre area for the number plate but i removed it all and cut the support bar down behind it also :D
give it a go
Brad
air going into your front bar ..at speed.... is pretty lazy it'll go around things to get past....
fit your cooler.. see how it goes.. if your really that concerned about the exposure its getting cut up the bar or get an aftermarket one with a big inlet
thats just my opinion. coz if u can see it ..the cops can see it.
if anything ..personally i would firstly move your number plate up (drill some lower holes on the plate and screw itback in place)..and probably to start with ..remove that rib in the middle...should be fine
Matt
take the number plate off. drill holes on the bottom of the number plate, make sure they line up with the original holes just at the bottom, fit number plate back on and screw it in with the bottom holes instead of the top ones.
Have a look at Al's stock frontbar for a good example IMO.
The centre bar has been chopped off, and the panel guy used plastic from the removed section to cover the C cutout section, smooth it out and repaint the
whole bar. It looks factory and not like a DIY chop off job.
just like what rs73 said, we cut out centre bar and plastic welded the C section... also we extended the depth of the intercooler hole about 4cm to give it a better look, but if you do this (extend the depth of the hole) you will need to position the intercooler a little further back towards the radiator, and by doing this you will need to have custom cooler pipes...
as i was getting custom piping anyway i did it so i could have a different look
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
