  • Replies 68
obviously theres not going to be a pits that will let everyone off with illegal stuff.
any dual pillar mount is illegal. your bov is illegal if it vents to atmo. your pod needs to be secured properly. your neons must follow the guidelines (ie. mustnt be able to see the tubes at all). your exhaust cant be too loud. you should be able to get permits for everything except the pillar mount and exhaust. they dont do permits for exhausts anymore apparently.
depends on the car, you and the inspector with what you can get away with.
When I got a yellow for being too low, I was told I needed permits for BOV (atmo), strut brace, pod filter, non standard seat rails. Already had permit for dual pillar gauge and exhaust. I went to Welshpool, and that was quite easy...aside from the 4 hour wait in line. They inspector crossed everything off, took it around the block and gave me all of the permits.
My brother in law is a cop, I asked him about permits and stickers and what he looks for. He told me that if he sees any more than 5 aftermarket mods he will ask to see permits. If no permits he will send the car off to get them, ie sticker.
He also told me that this is what he did, not a written policy - they can give you a sticker for any mod that doesnt have a permit.
If you are worried about getting a sticker off, it would be worth while IMO to go and see guys like C-Red, they have modded cars with permits and deal with the guys at the pits often enough to know what is ok and what isnt. Might save a bit of hassel.
Yeh I got done on Sunday night in the City at a booze bus, my friend behind me in his 180 also got done. On the way to go to Vic Park. Cant believe I got done for not having a permit on BOV and sticker on the windscreen. Had permits for everythin else. Twas such bu***hit! Thought to myself can they do this?
The cops we got were such b**tards. Said things like
- "this is what you get when you drive a car like this"
- "use your brains when buying a car"
- "You think youre car's hot, its not!"
- "Tell your friends that were coming to get them and that there is no escape"
And we didnt even back talk to get this kinda treatment. Also threatened to be arrested and further fined. I felt it was a real attack on jap cars. Anthing jap was getting sent to the side and checked for a "work order".
Really has left me pi**ed off all week.
Oh and "series 2" what were you doing when you got pulled over? were you speeding or just cruisin along.
Let us know how Welshpool is coz ive been told good things - I myslef have been to Warick and East Perth. Warick sux, East Perth not so bad it depends on who you get as an inspector.
And Im also worried that my suspension my be too stiff - will they check it again? anyone?
Cheers.
i got the sticker off yesterday at stock road got over with everything and got permits for everything .
Twista i was just going along booze bus and they pulled me to the side they reckon my BOV was to load but it was the bus behind me with their airbag or air brakes.
load of crap
Guys you gotta expect to be looked at when you're pulled over because the cars we drive standout from the norm and the cops know that we carry out mods.
If you don't bother getting permits who's to blame. I agree that they shouldn't give you any extra attitude because you drive an import, but remember they are human and will react to any attitude you show them.
When dealing with traffic cops be polite, your're on a hiding to nothing if you give them shit.
My understanding is that any mod has to be within the ADR guidelines (ride heights, noise etc) and technically should have a permit unless the mod is a standard fit to a model of car in the same range.
IE If you own a car that as an option had a larger wheel package available when new, you can fit wheels of that size without getting a permit. Always pays to check with licencing.
Insurance is another issue. HBF told me that my car will be covered as long as all mods are permitted by licencing.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
