Mate...
I'm in need of some slicks for my R33 GTS-t...
I read in Zoom that you ran 15x8.5" slicks on the back of your car? Did you fit those over the standard rear brakes? If so, could you please hook me up with some details on where I can get some of those "Convo Pro" rims?
Cheers mate,
Andrew.
https://www.sau.com.au/forums/topic/7667-attn-try09s/
Thanks heaps Brett!
A few more questions.
I'm deciding whether to use 26.0/8.5-15 or 28.0/9.0-15 MT ET Drags...
I have a manual gearbox, so I guess I'm going to try and minimize the shock on my drivetrain as much as possible... Would the larger diameter 28s be a lot harder to spin up, and hence place a larger shock on my gearset?
I'm assuming that it's easier to spin a smaller diameter tyre than it is a larger one? I'd love the softer sidewall of the 28s, but the increased drivetrain shock may not be worth it?
Secondly, I've decided to go with the Cragar Drag Star II /Weld Pro Star style rim... There are a few different options available, but I'm not sure how they translate into offsets and stuff...
Which one would be suitable for the rear of the GTS-t?
15 in. x 8 in. (5 x 4-1/2 in. B.C), 3-1/2 in. RS
15 in. x 8 in. (5 x 4-1/2 in. B.C), 43-1/2 in. RS
15 in. x 8 in. (5 x 4-3/4 in. B.C), 3-1/2 in. RS
15 in. x 8 in. (5 x 4-3/4 in. B.C), 4-1/2 in. RS
15 in. x 8 in. (5 x 4-3/4 in. B.C), 5-1/2 in. RS
Thanks again mate :mad:
https://www.sau.com.au/forums/topic/7667-attn-try09s/#findComment-112626
Hi merli firstly you will not fit the 28s because they will expand too much and hit the guards and you won't fit the 26x10s unless you fit solid bars instead of suspension as it was our first run with the 26x10s cought the side skirts and ripped them off and put a big dent in the tyres so i suggest the 26x8.5s i have run a handfull of 9sec passes at over 140mph on that size with a standard diff, drive & tail shaft as for the gearbox i cant help you there other than it's cheaper to replace a cluch than a gearbox so just flair the cluch a bit, as for the wheels i dont know off hand what the offset is but i do remember it was the most furtherists offset out that centre line do on the convos ring shane if you get stuck, hope this is of help.
brett.
https://www.sau.com.au/forums/topic/7667-attn-try09s/#findComment-112672
Excellent... I guess I'll go ahead and order 26x8.5-15s then!
You ran your passes on standard diff, driveshafts and tailshafts?!? I've already broken one driveshaft on my first outing! And that was just on 18" Dunlop Formula Rs! I was expecting to snap a whole bucketload when I put slicks on... Hmmm... I guess it's good news to hear yours have held up, hopefully the new one will suffice...
I'll give Shane a call and see if he can shed some light on those weird Imperial measurements for me :mad:
Thanks for all your help mate!
Andrew.
https://www.sau.com.au/forums/topic/7667-attn-try09s/#findComment-112710
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
