I just stacked my 32 gtr and need the following for the L/H side:
Headlight
Indicator
Guard
Door
Rear quarter panel
Rear tail light
Also need a R/H door
If you know of any wreckers with these parts could you please let me know. I don't really want my car sitting around. Need to get it fixed so I can most likely stack it again. Its true what people say about 32 gtr's "If you fight them they will bite you back". I just learnt the hard way.
Gareth
0417370869
https://www.sau.com.au/forums/topic/76681-parts-needed-stacked-my-car-good/
  • Replies 42
Performance jap specialists in campbellfield - there my close freinds and my good mate is the main mechanic there - they do excellent stuff, probably one of the only importers that dont "rip" people off and they do have a few panels - I will ask them for u Garreth.
Otherwise, in that area in campbellfield, I go and see all the wreckers around there (part of my job)and they have a LOT of GTR panels - campbellfield is like a Jap import parts heaven, u can find almost ANYTHING there, but you gotta be careful cos most of them will try to go to town on you and rip you off - best thing to do is tell them what u wanna spend, go a bit lower than that -and they shud give u the price.
But you would almost defeintly find panels - ive seen PLENTY of rear GTR cuts and fronts and 1000s of doors. Getting it in red tho? Dont like ur chances so youd have to get it sprayed. When im there during the week, I can ask around, so just PM me ur mobile or somethin so I can tell you.
Regards
Kim
Gareth I got to see you in the wall and was shattered for you mate. I'm just super glad your ok. Thats a fast spot and could have been a whole lot worse.
And honestly after seeing you burried in there I was never able to go flat out through there for the rest of the day.
Hope you get it all sorted as painless as possible mate.
:thumbsup:
Damn, That's an awesome photo!
Sorry to see the accident Rowdy... You had just passed me on the back straight when I saw the rear end lose traction at the left hand kink with lots of smoke and spin around then slide laterally/backwards helplessly into the tyrewall at about 100km/h throwing a few tyres in the air! I was like holy shit!!#@ gear down to 4th, continued around to the front straight until they got on the radio and called the red flag. Nasty to see it all happen right in front of me... the in car video footage would have been spectacular if i had a camera setup on the day.
All the best with the rebuild dude, good to see u put on a brave face when looking at all the damage.
:thumbsup:
Sorry to hear about the car G...
T&H in campbellfield have heaps of Nissan parts (GTRgeoffs excellent suggestion)
78 Horne St Campbellfield 3061 (03) 9357 1435
Probably get the headlight there at the very least.
Oh and btw we almost always haggle a heaps better price with them.
If you manage to find headlights and can't split a pair, let us know caus 46n2 is after a drivers side h/light & we'll go halves with you :D
Regards
Kim
speakin of panel damage n such, sum lady hit my 33 gts-t when i was turnin the other night, so i need parts for it, obviously easy to find as 33's are all to common in melb.
my question is, if i went 2 that place ( performance jap specialists ), what price you reckon i'd be able to score a new passenger door, new passenger seat, and mb a rear passenger panel ( not sure yet, that might jst need sum panel beating )???
also can you recommend some good panel beaters in that sort of area ( campbellfield etc ) coz i live about.. 90kms from melb but the panel beaters round here aren't to used of working on imports and i dont want a dodgy job done.
thanks in advance :D
Here are some picture of my car. I have tracked down all the parts except a front gaurd. Just for parts including a new rear quarter panel but not including a front guard it is only up to $1400. Also I spoke to a mate after work and I should be able to get into a heated spray booth for free. Hopefully I can pay the owner in beer to spray it or if not my mate will spray it. He does a good job on helicopters so a car should be easy.
Also what power is mats car making?
Troy whats the go with the wrx meeting and where is it.
http://img83.echo.cx/img83/6190/sky19of.jpg
http://img152.echo.cx/img152/9643/sky23ya.jpg
http://img296.echo.cx/img296/3530/sky38dx.jpg
How do you make pics show on the screen?
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
