It all depends on what else you have done. Be careful as a little change on the cam timing can make quite a big change to the AFR. Your best bet is to get the car on a dyno and work in small steps, monitoring the air/fuel ratios.
Just trying to clarify setting cam gears up....
what is the ideal setting?
4 advance on inlet side and 2 retard on exhaust?
If not what then?
thanks
and are these figure, cam gear figures or crank figures as 1 degree on cam is 2 on crank
Other way around. Most people have had success with about two degrees advance on the inlet & four degrees retard on the exhaust, but it varies from car to car. What you are going to be doing is increasing the cam overlaps - something Nissan couldn't do because of the emissions problems this gives.
1 degree on the cam is two degrees on the crank. Measure everything in crank degrees & don't forget to compensate with the ignition timing when you are done.
I would get it on a dyno mate, even if you have to drop the front tailshaft.
I would rather be sure then have someone who might have got their settings mixed up and end up with bigger problems (not having a go at anyone in this thread).
Cheers
Sumo
So...Can we get another to confirm its 2 degrees advance on plenum side and 4 retard on exhaust????
Yes, that is correct. Get it done on a dyno, because results vary from car to car depending on the tune and/or setup. The +2/-4 degrees gives you a good idea on where to start looking.
  • 9 months later...
I am wondering what type of tune my car has been steup for.
I had a look at the os giken gears and exhaust is retard 4 increments and inlet is adv 6 increments does this sound right to you guys?
What sort of effect would this have on the tune.
I have read that inlet is normally around 2 increments this seems very different.
The car goes really well just interested if it is setup to bring on boost or what?
mods rb26, exhaust, filters ,PFC 15psi, os cam gears.
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
