hey guys just been looking at some dash's of other peoples skylines and realised they arnt like mine
i was allways under the impression my instrument cluster was like that from factory, but i could infact bewrong (btw its a s1 33)
my second question is: i just installed the boostguage the other day, and is it normal for it to be reading 1psi while the car is turned off?
thanks
-Ruffels
https://www.sau.com.au/forums/topic/76718-is-this-stock/
the white bit ive never seen before, probably just an el kit or white background upgrade
i dont see how the stock guage should be reading 1psi? when the car is off or at idle its -500mmhg which is absolute pressure, its definetly not 0psi or 1psi
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405271
strange that Bigmicky lol coz my mate dropped it when we installed it... it still works fine... but instead of reading 10psi when i full boost it reads 11psi, which would explain the 1psi lol
can it be fixed?
and does anyone have any further ideas on the guage surround in the dash?
thanks guys
-Ruffels
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405284
and yeah... ive still got the reciept, packet and all for the boostguage, i bought it from ricer barn.. do u recon they give me a new one if i take it back.. or wil they tell me it has to be repaired by speco?
-Ruffels
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405285
i reckon some one has just put that in the back of the cluster, and with your boost guage, i installed my boost guage myself, when connecting the constant make sure u connect the right one. And when i turn the car off, it ends up reading 1psi, but as soon as i turn the car on it auto zero's itself and is back to zero.
ive got an autometer tho, so its possibly different
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405765
You open up the cluster.. paint that bit.. aftermarket facia cards are available in the correct size in japan - you can get carbon fibre look, etc. So it's either one or the other.
With the specco, somebody has shoved something in there too far, and it has jumped up. You can get inside and there is a spring mechanism - you kind of shove it back and you can adjust it up or down el'dodgo style. My old gauge often needs stuffing around with to get back on 0psi.
sorted..
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405861
As i understand it:
The boost gauge will only read vaccum / boost when the engine is running. The gauge will sit slightly eityher side of zero depending on what the air pressure (ie - the weather) is. Doesn't always mean that it's been dropped.
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1418856
Standard air pressure at sea level on a 15'C day is 101.3kPa, or 1Bar. That's 14.7psi iirc. Give or take a little based on daily changes.
Yep, the gauge will only display something other than zero when the engine is running :uh-huh: but 1psi is the air pressure at around 28,000ft.
Mark
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1419360
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
