Hey
Ive got a R32 GTR which is pritty much stock it just has a Trust 3.5inch cat back when it arrived from Japan. Running stock boost also.
I want to give it a bit more power and would like about 250kw at the wheels and the car to be reliable as it is now. I also want to keep the engine bay totally stock looking including the airbox.
What kind of mods and prices would i be looking at to get this figure ?
Would you sugest some N1/Group A turbos or aftermarket HKS ones ?
Thanks!
https://www.sau.com.au/forums/topic/76731-increasing-power-r32-gtr/
I have full exhaust (standard dump pipes on turbos) run 1 bar and have power FC which got me 226 kw at all 4 wheels (still have standard airbox, BOV, and intercooler), this should at least be the starting point.
The figure you require is easy to reach with injectors, different turbos and the above and you will also be able to keep engine bay looking stock!
So im guess Power FC, 1 Bar boost, injectors and turbos should get me 250awkw ?
Would N1 turbos eaither off 32/33/34 be fine for 250awkw ?
Would i need to upgrade the fuel pump ?
Exhaust, CAM Gears, 1 bar boost (and maybe a PowerFC if needed) and you'll get 250rwkw easy.
So would a set of these offer much of a performance increase when used with standard cams?
And are they hard to fit / Setup...?
Should do, may need to run more than 1 bar (from what I have heard 1.3 bar gets mentioned a lot).
I'm pretty sure N1 turbos of any series GTR will do the job as they are able to run more boost due to steel turbines, but I think the 34 n1 are the only roller / ball bearing ones.
This should result in anything from 250 to 300kw at all 4 wheels.
so wat sorta rwkw would i be expecting from a RWD rb26 setup in a silvia with twin 3inch dumppipes(twin 2n half with custom screamer pipes if i get around to makeing them) into single 3n half inch, FMIC, stock turbos 12psi, MINES ECU, and fuel pump
i know i'll find out soon enuff when i dyno it.. but is still a lil bit away
Excuse my ignorance :thumbsup:
But what do they use to restrict boost, and how is it removed...?
I know on R32's where the boost line meet's up to the boost solenoid there is a boost hose there with a yellow stripe on it and if you squeeze along it you will feel a hard bit in there like there is a marble or something stuck in there.
Pop that line off and squeeze it out then pop the line back on, that should bump boost up to around the 1 bar mark give or take a little.
The solenoid is mounted up on the drivers side strut tower.
Hope this helps.
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
