Hiya guys, it’s been an expensive long weekend. I've had my 33 for 5 years now and this is the first time I’ve been defected - Lucky yes.
Defects are as follows:
Carbon Fibre Bonnet
Too Low
Too Loud
Blow off valve not connected to stock engine pipe
Insecure Air POD
Pillar gauges
The cops were great and we had about a 45 minute chat about the car. I've got a little over a month to get everything fixed at the local police station.
I've currently got TEIN HA Coilovers installing without the helper springs - Will I be able to adjust the height enough to get it legal? It's going to be a pain reinstalling the helper springs.
The only other thing is the exhaust - 4 1/2 " catback with an angled exhaust. Will this need to go back to stock to pass the DB test?
I've still got the original bonnet - already secured the POD and removed the Pillar gauges.
https://www.sau.com.au/forums/topic/76777-help-finally-got-defected/
Bugger hey, 5 years and no defects is good going though :D
At least they got you for actual defects, not trivial things like an empty washer bottle and stuff.
Good luck getting them fixed.
Question with your gauges though, were they in a holder up the a pillar? Did you have 1 or 2.
what does the form say ?
on the front it should have a cross on one of the following
1 ) cease using the vehicle after _____am/pm pm __/__/__ until replacements,repairs or alterations set out below have been carried out.
2) produce the vehicle for a full Certificate of Inspection.Safty Certificate inspection at an approved inspection station.
3 ) produce the vehicle for further inspection of the defects set out below at/to (what ever the copa writes mine have said Goldcoast traffic Branch coomera) at/by __/__/__ or by appointment.
which one of those have been selcted ?
then obove all that if should say Defect Classification
Self Clearance [ ]
Minor [ ]
Major [ ]
Major (dangerous - label affixed) [ ]
those options relate to info on the other side of the notice and explain what u have to do to get it all sorted out.
Melv
I received one defect notice with all the defect listings & two seperate fines - one for the bonnet and the other for Driving Defective Vehicle.
Produce the vehicle for a full Certificate of Inspection/Safety Certificate inspection at an approved inspection station.
and
produce the vehicle for further inspection of the defects set out below at/to ( Palm Beach) at/by __/__/__ or by appointment.
It's also a Minor Defect Classification.
Just the 1 - nice cop.
lucky very lucky! i just got done the other weekend for an illegal uturn at traffic lights and that cost me 2 points. + $60. i had a green arrow aswell. so its not like i was doing it dangerously. its gotta make you wonder how they work out the points system. 2 points for what i did is rediculous!!!!!
Wasn't down the esplenade was it?
Sunday afternoon (and probably a lot of other times over the weekend).. 2 cop setups about 300m apart, doing inspections on pretty much any car that looked half modified.. Seemed a bit extreme to me to have two lots doing it so close together. Somehow I managed to avoid them though, lol..
End of the financial year is rapidly approaching - careful folks :)
I got defected for noise and i had a 3" turbo back system (with cat) rated at 98db. To get me down to 90dB (the limit), the exhaust place put in a hotdog resonator and silencer for the cannon. I'd say for the 4.5", u might need another muffler squeezed in. As for the sound test, I had trouble finding places in Brisbane who could do it (cos ppl had their machines being repaired) but if u need to come all the way to Brisbane, Valley Exhausts near RBH do the dB test for $55.
a friend of mine got booked for doing 28 in a 40 zone, he was going slow because the truck infront of him was droping crap off the back as it drove and he wanted to keep a distance, the truck wasnt even going 40 too.
i think the cop was just picking on him for his line.
Hopefully i can just fit a Silencer to the exhaust - The Officer said the police station will handle the DB test.
With the Coilover Suspension - I should easily be able to get it to a legal height without fitting the Helper Springs - Thankgod.
" End of the financial year is rapidly approaching - careful folks " - Pricks !!!
After having just been through this and doing a truckload of research
Carbon Fibre Bonnet - Illegal and there is no mod plate u can get nothing.
Too Low - Raise it, Coilovers are illegal as they do not meet ADR's
Too Loud - Take it to an exhaust shop that can do Db readings and get it made quiet along with a form to say that its quiet.
Blow off valve not connected to stock engine pipe - Blow off valves are not illegal regardless of where they are connected as long as it still meets exhaust emiisions.
Insecure Air POD - This i was told was by a transport officer is a bullshit fine, there is no ADR or rule for it.
Pillar gauges - Was also told by the transport officer that they are legal as long as they are not lcd displays and does not hugely decrease vision.
I also have the light vehicle modifications hand book, not the pamphlet the big thing u buy from the government, and all the ADR's to back up what i have just told you.
Yeah, i'm taking my car in with the coilovers at a legal height.
Should i worry about the BOV ? Its listed on the defect - i've got the right kind of BOV to connect to the stock pipe. might just get a little extension just incase.
What is the legal height again? I have Tein HA and there is a limit in which you can raise at the front. I put it at the max height but the front bar is still only 9cm off the ground.
Out of interest what if the car was complied with items such as the CF bonnet, and say coilovers? (15 year rule, or pre RAWS?)
Dave,
Nothing against you here... But a few times i've seen you post regarding being 'invincible' from defects because the mods were 'on your car when it was complianced, so therefore its all legal'
I think thats a bit of blind hope there and really wouldnt hold any weight at all... If a mods illegal its illegal and they'll get you for it. After all whose to say that certain mods werent put on AFTER it was complied... just food for thought
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
