Dave,
Nothing against you here... But a few times i've seen you post regarding being 'invincible' from defects because the mods were 'on your car when it was complianced, so therefore its all legal'
I think thats a bit of blind hope there and really wouldnt hold any weight at all... If a mods illegal its illegal and they'll get you for it. After all whose to say that certain mods werent put on AFTER it was complied... just food for thought
Hence I said out of interest. If hes got the book I guess it would be in there somewhere.
Like wise how can they say they have been put on after. My point with that is, which I feel is fair, I paid my $1200 to have my car complied (as would many others) and I think its wrong Id get the fine when Im not the one at fault, because as far as Im concerned my car has been put though the proper channels to make it legal. That and my understanding of the 15year rule it was different to a normal blue plate.
And adding to that, if the mods are illegal, they shouldnt be going after me (although easier) they should be going after the dodgy compliance shops, the dodgy blue platers, and the lack of DOT picking it up once its been through both of the other so called safe gaurds. And really fix the problem properly. But we cant have that :rofl:
End of the day it doesnt worry me too much, Id just like to know for sure a bit more. I keep the car as legal as I can without being stupid about it. Really I know if Mr policeman wants to book me, they will, they will find something such as 'windscreen wiper blades are too hard, or too soft, or too black, or made out of the wrong rubber or, I look like his daughers ex boyfriend'
a quote from my other thread,
"Bottom line is, if u are concerned about being defected put your car in the garage and never drive it again. They can and will do u for anything even if they make shit up.... Yes u can fight it but most people dont... its what comes with owning an import or performance car and u have to take the good with the bad."
Even opinions vary from inspection stations and between inspectors in the one station, they got into a verbal fight over my car, its all a matter of opinion, its ****ewd but there is not a thing u can do about it.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
