Anyhoo down to business.
The usual 100km service, done all my fluids recently but am going to get cambelt and others changed and water pump. My question is, in amny other threads people say you should do your "idle bearing". What exactly is the idle bearing? what will happen if it breaks, and how much more will it cost rather than having it done at 100kms?
Thanks guys.
https://www.sau.com.au/forums/topic/76782-wow-another-100km-thread/
It is a wise move to replace the Idler and Tensioner Bearings at 100,000km. They may only be a little bit noisey but in another 100,000km they could potentially become seized which is very bad news as the belt will then break and as a result bent valves will occur.
My bearings were pretty average. I replaced the tensioner bearing and idler bearing. I bought as whole pulley with the bearing inside. Under $100 for the 2.
My water pump seemed fine and my crank and cam seals weren't leaking so I left them. Some say you should replace crank and cam seals but I couldn't be bothered taking the rocker cover off and the camshaft pulleys. Also I thought a few less things to get wrong the first time I did a belt change.
I did the most important things. If there was any sign of oil around crank or cam seals it is wise to do them. If you take it to a shop I would get everything done as it costs $ if down the track something needs doing, whereas If you do it yourself you will just kick yourself for the wasted 3-4 hours...
Torque up idler bolt and tensioner nut to correct torque.
Also if oil does leak from crank and cam seals it will shorten the life of your belt possibly without you knowing.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
